Pole saw is a wonderful machine that has a small curved saw blade mounted on its long handle and used mostly for pruning hard-to-reach branches. Now, if you have already learned about its functionalities and got a hold of them, you must be very excited to use it. But, working with a pole saw can never be easy without its being ready. A proper assembly is a key to that readiness.
No rocket science indeed! We're explaining the whole job easily and legibly.
STEP 1
Knowing the parts and components is a crucial factor. You should know what an average pole saw includes and make sure you have got all of them. A usual pole saw consists of the main body, pole saw, chain, bar, cover and hex key that contains screwdriver attachment.
STEP 2
The next step is to uncovering sprocket on the main body. It can be done by taking the hex and unscrew the pocket over the bolt. Rotate the hex in an anti-clockwise direction and take the cover out of the body.
STEP 3
As the cover is removed, the following task is to organize the chain and straighten it. In this case, if the chain should be in the right travel direction. If it is not in the right direction, you should loop over the chain and set in a way so that the teeth adjust with the bar.
STEP 4
When the chain is set properly, you should link the chain drives to the bar groove afterward. You should connect the chain carefully and ensure that it is attached accurately. Otherwise, a chain that is not fixed correctly may lead to a serious accident.
STEP 5
After the attachment, a loop remains at the end of the bar. Now, take the bar and place the loop on the sprocket and adjust the chain with it also. Before you do it, you should loosen the tensioner pin with the help of your fingers. It is done to confirm that the tensioner pin passes through the tensioner hole on the bar.
STEP 6
As the chain and bar are fixed to the sprocket, it is required to tighten the chain tensioner screw so that the bar and chain can hold and stay on the sprocket. The screw needs to be tightened completely in this matter.
STEP 7
This step involves covering the sprocket. Take the cover and insert rear tab into slot. Just placing it in the slot does not secure its placement. So, to attach the cover take the hex key, put in the bolt and turn it into clockwise direction but not too tightly. The cover is lightly fixed so it can create room to work with the tensioner.
STEP 8
You should remove all the slack from the chain by turning the chain tensioning screw clockwise. By doing so, the chain and bar stay in its place safely. After this, tighten the sprocket cover bolt using the hex key again.
Source:
Step By Step Guide to Assemble Pole Saw
SOURCE: How to assemble the saw to the pole.
Leave a comment if you need more help.
Thanks for using Fixya.
