Just got a Pixma TR8520. Set it up wirelessly to print w/PC first and it scans to it fine. Set it up wirelessly on my laptop. I can print to it, but I cannot scan from the printer to it. It only shows the PC to scan to. Please help!
Solved
Appreciate your getting back to me. I did manage to figure out it was "user error". I had to launch part of the program "Network Scanner Selector" to ensure I wanted my laptop to be selectable from the printer in order to scan a document to the second computer. If anything, perhaps my error can help others. Thanks again for this great community! This issue is now resolved.
Customer care support service number +1--833--[272]--0777,,__,,,,,call them__
There does not appear to be anything wrong with the cartridges (there shouldn't be - they're new), but the cartridges will not center when the cover is lifted. So I can no longer print anything, and I can't check the cartridges - help!
Any information anyone can provide would be greatly appreciated. I'd hate to replace the printer, it's still in very good shape.
It is just a part of e scanner printer but they are having their own brand and name for the users to be inactive part just because the things which you have to know it is very sensitive, so for that only you need to know the dell tech support for any query related question. Home Dell Supports Call us for any Dell Support 1 888 2233 112
SOURCE: scanner won't scan to pc
Is the error message Epson Scan cannot be started? What is the Operating System? Is the printer directly connected to your PC?
SOURCE: printer x6570 won`t print photos and data, or scan...
try uninstall the driver and insatll it after that reboot and connect printer!
SOURCE: C4480 cannot scan to pc
I can not scan from my printer to my pc. I have a hp c4480. everything works on it. bill
SOURCE: scan from printer through router to pc?
You will need to use the TWAIN software for the printer. From the computer you will be running the scan options thru the TWAIN software. Then the scan files will be pulled from the printer back to the computer. Running scan options directly from the printer will give you the option to print the scan files or send them to a memory card if your printer has a slot for one. If the scanning software is not installed on your computer then you will need to download it from the manufacturer's website.
SOURCE: Lexmark 5400 series all-in-one fax printer scanner copier
This is not so much a solution, but I have a lexmark 5400 printer -and I am also having problems with "alignment." I just replaced the cartridges an now I am getting an error message saying: "Alignment problem, remove tape from cartridges, check paper and then press the check-mark button." There does not appear to be anything wrong with the cartridges (there shouldn't be - they're new), but the cartridges will not center when the cover is lifted. So I can no longer print anything, and I can't check the cartridges - help!
Thanks
Hi Trish Kehoe, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
Did you install scanning software from printer manufacturer on all P.C's
and are all P.C's got a workgroup name and are they the same as one p.c. that works ?
best ever website for roblox is herehttp://robloxrobuxtix.com/ lets check it out guys
roblox hack
https://hindidialogues.in/attitude-shaya...
Attitude Shayari In Hindi For Boys/Girls 2019 (images) Attitude Shayari are the most popular category of Shayari everyone looks for. ... You will get some new and trendy attitude Shayari in Hindi & English language from here.
