When I put it on a 14 minute wash it doesn't allow any water into the washer but when I move the timer up to 12 minutes it fills up the washer & it starts washing plus it goes through the rinse cycle like it should. Everything is fine except for when it's on the 14 & 13 minute wash cycle. I'm thinking the contacts are bad in the timer. Does anyone know for certain ? Thank You
SOURCE: No pressure to drive swing arm.
Check first that no debris is blocking the holes in the spray arm where the water comes out, and clean out the holes. In case it will not solve your problem, it's look like a pump problem (the pump has two functions : drive water to the spray arms and to drain water out the washer). Open the rear panel and listen if the pump works during the wash cycle. In case it doesn't work, it should be replaced. Good luck !
SOURCE: Wash cycle not working...
Kerbri, it sounds like your pressure switch could be the culprit. Under the top console the switch will be on the left side. There will be a clear tube that runs from the tub to the switch. Take another piece of tubing about the same size in diameter, disconnect the tube to the pressure switch and connect the tube. Blow into the pressure switch and see if the washer starts agitating. If so, replace the pressure switch.. Another thing to check would be the harness to the motor, make sure it is on tight. Good luck
SOURCE: Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
[email protected]
