My bosch dish washer model 'sms68mw02e' has got a problem! Once it was working and child lock(display child lock) was activated, before finishing the program, I opened it's door and then unpluged it. But next day when i wanted to reload an start to use the machin again, the display was on 'eco' and just flashing! No other key is working! How can i fix it!?
SOURCE: Can't deactivate child lock on washer
Try: Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
SOURCE: Kenmore Dishwasher does not wash
my problem is the motor hummms for a minute or so and turns off. Could this be the capacitor? how do you test a capacitor?
herb
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
SOURCE: Bosch Nexxt Essence Washer
i have the same problem with a bosch at a rental unit i just moved into. the door is locked up until the 25 or 41 minute cycle depending on the cycle used.
$500 to fix the motor, YIKES! and its my responsibility, yikes again.
definitely a motor problem not a door problem.
SOURCE: How do you get the child lock off?
Please find complete process to switch off the child lock.
http://www.ehow.com/how_5144877_turn-kitchenaid-dishwasher-child-lock.html
Most of the dishwashers are same so the model should not be a problem
Thanks
Your washer is in the
"child lock" mode, hence it won't allow any program. Press the "menu" button until you
see "CHILD LOCK :ON" appear in the display. If nothing is pressed within 10 seconds.following
this the menu will close and it will default to program in the display. Once you see that in the display, press the
"select" button until "CHILD LOCK :OFF" appears in the
display. Finally by pressing the
start/pause button the key symbol should disappear - confirming you have
successfully exited the child lock program.
Pl click if helped.
Pl click if helped.
