Bottom freezer, I can see condenser behind vents, and the whole thing is freezing over, not allowing the fridge to cool. We used the blow dried to melt the ice and then the fridge cooled and all was fine. Now a week later, the condenser is freezing the vents closed AGAIN. If we take the cover off the back of the fridge, what do we look for? How can we fix this ourselves. Thank you!
There are a few things that it could be. Do you mean the evaparator coil? This would be the coil on the inside of the freezer, the condenser is outside the unit. If the evap. coil is freezing, you could have to much in your freezer blocking air flow. You could also have a evap. fan not running. Check the owner's manual for the location of the defrost timer, it could be bad. The thermostat needs to be checked and set so that it is at a reasonable level. One last thing to check would be the condensate drain. Make sure the drain is not plugged or the line is not plugged. Good luck.
Many times a freezer and/or refrigerator do not work right because of
a dirty condenser coil...there are also many other things that can go
wrong.
If
you are hearing a clicking or buzzing then check out the last two
tips.
If your refrigerator is running but warm, then...
Check
out these tips that I wrote about that... it is a great place to
start trouble shooting your unit...and something that you can do
rather then calling a repair person to do a simple thing for
you...
Refrigerator Condenser
Coil Cleaning
Refrigerator Repair
Refrigerator
Troubleshooting
Refrigerator Compressor
Refrigerator
Compressor
Start Capacitor and Start Relay
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
