Question about Kenmore Refrigerators
Freezer compartment drain trough misaligned, so hole at bottom of trough and the tube drain hose don't line up. Kenmore side by side refrigerator model 253.5567440N
Because the holes do not line up, a small amount of water freezes under trough, and also leaks out to drip along the drain hose and onto floor. Is this a design flaw? How did the trough become misaligned? It is firmly attached to compartment walls. I can manually, with difficulty, push on the bottom to align the hole, but it does not stay. It does not connect to the tube drain by design! Kenmore side by side refrigerator model 253.5567440N
    Passionate:
    Visited the website for 10 consecutive days.
  • 128 Answers
These often never line up and shouldn't be an issue. The most likely problem is a slow/or blocked drain. Sometimes you can flush it with hot water and it will clear it but sometimes it needs to be removed and maybe flush it outside from the garden hose or in the laundry room. You would need to pull the unit out and remove the bottom cardboard cover to get to the drain tube.
Freezer compartment drain trough misaligned, so ho - r0508004-00006-3dvc3rq02kdqjihqd3tusqf5-3-0.png
Posted on Apr 10, 2018
Anonymous
SOURCE:
Michael Anderson
  • 172 Answers
SOURCE: Leaking Freezer (top) on a GE TBX10 refrigerator
Your refrigerator is frosting up and your drain is freezing over. You will most likely need to defrost the coils in the freezer and the drain. Check the heater and defrost thermostat for continuity and replace if bad. If heater and defrost thermostat are both good you may need a defrost timer or control board.
Another item to consider is a defrost drain probe. This item attached to your heater and goes into the drain to keep it from freezing over. Good luck to you and I hope this helps you.
Mike Anderson
Posted on May 08, 2008
Anonymous
  • 16 Answers
SOURCE: water leaking from bottom of freezer compartment
the condensation drain line might be clogged.
Posted on Jan 02, 2009
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: GE TFX20JR side by side/water leaks out freezer during defrost
Yes, you are correct, that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrig. (where the air blown over it will cause it to evaporate)
Posted on Jan 06, 2009
Maytag317
Victor
  • 1136 Answers
SOURCE: freezer icing over at bottom and leaking onto floor
Hi, You will need to remove the rear panel in the freezer and then remove the ice build up in the drain pan. The drain hole will have ice down in it.Make sure all the ice is gone and then flush the drain hole out with hot water (a basting serenge works great)
This should take care of your water problem.
If I can assist you further, please let me know and please rate me response so that other as well as my self will know how I am doing.
Thanks
Vic
Posted on May 23, 2009
Anonymous
SOURCE: Water build up back of freezer inside
Our GE Profile leaked from the freezer door and this is what I was told by a service man to try before he came and it worked. There should be a "well" on the bottom of your freezer floor where the water runs when it defrosts. Yours is probably now covered with a sheet of ice. You can melt the ice with a hairdryer using dry towels to soak up the water as you work or really hot wet rags and ring them out in the sink. After all the ice is removed pour a small amount of warm water into the "well" and stick your finger in there and "plunge" it - like you would a clogged toilet - with your finger. This will purge the ice that blocked the drain. Check on this every couple of months to make sure you don't end up with the same problem in a year or so.
Posted on Jun 26, 2009
I have water on floor under refrigerator.There is no water supply line to this frig.
If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013
SOLVED: Water leak in refrigerator? - Refrigerator - iFixit..or go to this link might help you as well....
water on floor under refrigerator Google Search
Oct 23, 2017 | Refrigerators
I've got a 2006 Saturn Vue that keeps getting water in the front, under the floor mats. It appears to be coming from the center underneath and behind the instrument cluster/center console. Could this be...
The most common source of water on the floor is a plugged a/c evaporator case drain hose. This drain is generally located down low on the engine side of the firewall at the passenger side and is usually a small short open ended hose that points down. Debris and bugs will clog this hose which makes the water that condenses on the evaporator [whenever the a/c is on] overflow and leak out of the heater/air conditioning housing and onto the floor. If it hasn't rained for some time yet you are still getting water on the floor I would bet on this hose being plugged. A puff of compressed air is enough to clean most of them out. Most sunroofs have one or two small drain holes that allow water to run down through the door pillars and onto the ground. If you pour a small amount of water around the top edges of the sunroof when it is closed you should soon see water dripping onto the ground under the outer edge of the vehicle. A few sunroofs just rely on tight weather stripping to keep the water out but those usually drip water on the driver or passenger if they are leaking. I see a lot of leaky windshields but again, it has to be raining for water to get on the floor from them.
Jun 14, 2010 | 2006 Saturn Vue
Ice builds up in bottom of freeze side by side
This is usually a plugged drain trough. Every time your refer defrosts itself, the melted frost drips off the evaporator behind the wall of your freezer and drains into a drain trough, through a hole and into a drain tube that ends above a condensate pan where the heat of the compressor-condensor evaporates the water. Food gets into this drain line and plugs up your line, causing it to freeze the melted water into a slab of ice that eventually drips onto your floor. Most units you have to remove the freezer back panel inside the freezer to get to this, although some models you can see the drain trough without removing the panel. You can use hot water to clear this. Flush it out until you hear water pouring into you condensate pan. I use a garden pump up sprayer to shoot pressurized hot water through the drain line to make sure it is cleared out. Needless to say dont use this if you have had any poisonous chemicals in your sprayer. Good Luck, Appliance Specialists
Dec 14, 2009 | Washing Machines
HOW DOES THE EXCESS WATER DRAIN FROM THE BOTTOM ON THE DISPENSER. I DRIED UP ALL OF THE EXCESS WATER AND CAN NOT FIND ANY DRAIN HOLES FOR THE WATER TO DRAIN AWAY. WE HAVE MOISTURE ON THE FLOOR AT THE FRONT...
is the water coming from the water dispenser on the door or from inside the freezer ? if from the water on the door, there is no drain..if the water continues to drip from there, you have a "air leak" in the line somewhere. If the water comes from the freezer, there is always a drain line and hole there, sometimes it is behind a panel, but it is there usually covered with ice if it's dripping out onto your floor. You need to let that ice thaw and I use a small hose (6' long) that will fit in that drain hole,get it at a hardware store.. fill the hose with water and push or plaace it into that drain hole..blow that water into the drain hole so it will wash out what might be in there causing the blockage. This amount of water will go down into a catch pan (already there) and evaporate. Restart your refer and watch for it in a week or two if it's back, do it again or check the drain tube on the bottom back, for any kinks.
Oct 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water in bottom of refrigerator has to be removed every couple of days or will come out onto the floor.
under the vegetable tray, a small drain hole is stopped up.Everytime you unit goes into defrost mode,the water is not draining to the defrost tray under unit
Sep 25, 2009 | GE Refrigerators
Leaking water from the defrost
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Mar 20, 2008 | Refrigerators
Estate TT21AKXKQ Refrigerator Leak
Mar 17, 2008 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Sub-Zero 550 water dripping on right side of freezer forming ice on draw
I had a similar issue that started about a year ago with my Sub-Zero 550. My freezer gasket actually tore after several times of freezing closed. I thought that a new gasket would solve it, but a second but related problem developed where I was getting alot of condensation under the left side of the unit, with the water dripping onto the floor...eventually staining the hardwood floor in front of the unit.
I traced the problem to a clogged condensation drain pipe in the refrigerator. It is a corrugated pipe that drains a trough behind the crisper drawers. My pipe was clogged with black sludge and frozen down below. The condensation in the fridge would overflow out of the trough and leak below the crisper drawers, down out through the gasket.
To resolve, I used a piece of solid thin wire folded in half and twisted with a small loop at the end to fish out as much sludge as I could. Then squirted hot water into the pipe until it totally unclogged. I believe this will solve the problem without any need for a heater underneath the unit. The 550 worked fine for 4-5 years before this happened.
Jan 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Water leaking frigidaire frs23h5as
yes remove the rear panel in the freezer where you see the drain hole. Clear the ice from the drain hole. It will take a while for the water to start to drain because the ice is deep in the insulation. A small tube is helpful to draw some hot water in and stick in in the drain hole and squirt the hot water down in the hole.
Nov 25, 2007 | Frigidaire FRS23H5AS Side by Side...
Refrigerators Logo
127 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
