SOURCE: crosley front load washer one year old. doored
your drain pump or hoses are blocked with foreign material,either coins,hairpins,detergent residue from earlier washings,remove the front lower access panel if provided to access the drain hoses and pump and also check the drain itself,some washers have the access door in the back side of the machine,if the stand pipe in the house is slow to drain it can back up and cause back pressure and the machine will sense this and stop also
Thank you for your post, derek dion!
From the information you have provided you need to know how to access the drain pump on your Crosley washer. I was unable to locate a step by step instruction sheet on how to access the drain pump. From your parts manual you would need to remove the front panel and it is located directly under the drum. If you are having trouble locating it or removing the front panel I would recommend contacting a professional technician for proper disassembly and repair. Best of luck! -OOS
Hi - Are you certain the error code is L7? This manufacturer does not have any L7 error codes for any washer or other units. I understand that it will not spin either; does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly.
