SOURCE: ford fivehundredright rear brake caliper wont retract
Is this the ratcheting style caliper? If so, you really should be using the proper tool to turn these style calipers back into their bore, and both calipers should turn clockwise to retract them back in. Also, if the piston was too far out you may have a hard time getting it to go back in. Hope this helps.
SOURCE: power steering noise
hi..you can add some power steering fluid to stop
the power steering noise.
try this out..
thank u..
rate me..
SOURCE: I HAVE JUST BOUGHT A GM 5.0LG SGI ENGINE, WITH
site i use for casting numbers is down at the moment
far as if a camaro motor would work in your truck yes small blocks between trucks and cars the same
there are 2- bolt main blocks
and there are 4-bolt main blocks
2 and 4 bolts are used in cars
and 2 and 4 bolts are used in trucks
main differance between truck motors and car motors are the add ons intake exhaust manifolds
heads the blocks them self are the same
trucks are usally geared lower but that in the tranny and rear end not in the motor
soon as my site comes back up i look up your number for u and give u link to site as well
SOURCE: 2006 Ford Fiesta, Left side
yes,have an idea! when the turn signal works on one side or other really fast, you have a blown front or back blown turn signal light bulb.remove the back first,it's usually the one that blows fisrst,but not always! you may have to look or inspect the rear bulb. it will have a blown element in the bulb itself.look at the bulb for a very small wire inside of the bulb,if the metal ring inside the bulbs broken into.it will not work. unfortunatlly, you will have to remove one at a time. i would start at the rear,unless,you've hit something,or been stuck in snow from the front side. if you have been stuck in snow,i would go to the end that's been stuck and start there.other wise just start at the rear and check for a blown signal light bulb.it will be in the yellow portion of the turn light. the bulb that lights up the yellow portion of your tail light turn signal.if it's in the rear,you will need to access the bulb from inside the rear hatch assembly. if in front, you will need to remove the turn signal light. hope i've helped you! thank you for choosing fixya.com
