Question about Nikon Optistation 7 Yaskawa Xu-rcm2500t-3 Robot Track Ost7-01-031-3 Working
480vac yaskawa ac 50hp motor drive ' Inv. ol fault, i checked ground reading good , i do not kown problem , i need more info.about it
50hp Mercury outboard electrical schematic
Hey David,
Yo should find all the info you need here..this will be very very helpful...' Mercury Outboard Manuals by Seloc 1965 2014
Jun 07, 2017 | Mercury Boating
When i turn on the drive it display it display code for ground fault. my wiring are correct. And i cannot use keypad of drive. how can i resolve the fault .
why cant you use the keypad/'display of drive, is it not lit up ? if so you most likely have a grounded phase on the load side (motor) I suggest disconnecting motor completely and measuring to ground with a high voltage tester (megger) if you have a phase to ground then all the power that drive puts on that wire will shunt to ground , causing infinite current , this will affect the power supply of drive and not allow drive to even power up correctly
also you failed to mention if motor was 3 phase if so , some drives require installer to remove shunt jumpers (see install directions) this will "Lift" the surge suppresors off earth ground and over to "virtual" ground that occurs at center of three phase power , this might be seen as a ground fault if this is not done correctly
Jun 12, 2015 | Delta Vfd750b43a Ac Drive Vfd B Inverter...
2005 Honda CG 150 Titan ESD not charging
Hi, Venzgalutera before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Battery Test:
The battery needs to be a fully charged and load tested to ensure proper readings, connections need to be clean and tight. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test:
Start motorcycle, measure DC volts across the battery terminals you should have a reading of approximately 13.2-15 DC Volts.
3. Connections and wires:
Inspect the regulator stator plug, and check the battery terminals for connection corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC output and resistance test fail and stator test passes then the rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Unplug the regulator plug from the stator start motorcycle and change Voltmeter to AC volts. Probe both stator wires with your meter lead. The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. Reading will vary depending on system, check service manual specification
Generic Specs:
22 amp system produces about 19-26 VAC per 1,000 rpm
32 amp system produces about 16-20 VAC per 1,000 rpm
45 amp system produces about 19-26 VAC per 1,000 rpm
Stator Resistance Check:
Switch your multimeter to Ohm x 1 scale. Probe each stator wires with meter leads and check resistance on the meter.
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on the system, check the service manual for specifications.
Generic Specs:
22 amp system produces about 0.2 to 0.4 ohms
32 amp system produces about 0.1 to 0.2 ohms
45 amp system produces about 0.1 to 0.2 ohms
5. Stator Ground Check:
Probe each stator wire with your positive lead on the multimeter and the negative to ground.
There should be no continuity to ground on either wire.
If there is continuity your stator is shorted to ground and must be replaced.
6. Regulator Test:
Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Battery Charge Lead- Wire going from the regulator to battery positive.
AC output leads- Wires coming from the Stator to the regulator.
Ground- Wire from Regulator to ground or regulator may be grounded via the physical bolting to chassis.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from the regulator body to chassis ground).
Fwd/Reverse Bias Test/Diode Test:
This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
Switch multimeter to Diode Scale.
Place your Multimeter positive lead on each AC output wire.
Place your multimeter negative lead on the battery Charge wire.
The meter should read voltage typically around .5 volts.
Next, switch your multimeter leads putting the negative lead on the AC output wires and the Positive lead on the Battery Charge Wire. The reading should be Infinite. With your meter on the same setting, place your multimeter positive lead on the regulator ground wire or to the regulator directly, and then place your meter negative lead on the AC output leads.
Next, switch your multimeter leads putting the negative lead on the regulator ground and the Positive lead on the AC output wires. The reading should be Infinite.
Note: Below is a table to show the readings:
Positive Lead Negative Lead Reading
AC output 1 Battery charge lead Voltage
AC output 2 Battery Charge Lead Voltage
Battery charge lead AC output 1 ?
Battery charge lead AC output 2 ?
Ground AC output 1 Voltage
Ground AC output 2 Voltage
AC output 1 Ground ?
AC output 2 Ground ?
For more information about your issue and valuable "FREE" downloads for viewing or printing that you will need please click on the blue links below. Good luck and have a wonderful day.
http://racetechelectric.com/files/pdf/rte_troubleshooting_flow_chart.pdf
How to test your motorbike battery with multimeter multimeter tutorial
manual motor honda cg titan 125 pdf Honda Motor Vehicle Manufacturers
http://www.partsfish.com/page/oem-parts-for-honda
Honda CG150 Titan ES Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 23, 2014 | 2005 Honda CG 150 Titan ESD
HOW TO TEST A BLOWER MOTOR
To test the motor windings, use a multimeter to ohm out the common wire wtith the remaining wires of the motor, youn should read resistance, if you read OL on your meter the windings are bad. To test for a short to ground, check the resistance between each motor wire and the motor frame, you should not read resistane ifnyou do the motor is shorted to ground. To test mechanically, spin the shaft by hand, it should move easily, if hard to turn replace the motor. You can also apply power directly to the motor and if it does not start replace motor. Hope this helps
Dec 11, 2012 | Dayton Gas Furnace Heater
Ttr 230 wont start with new battery
Hi, Grant the following is a comprehensive charging system test that is guaranteed to the find issue with your system.
1. Battery Test: The battery needs to be a fully charged and load tested to ensure proper readings, connections need to be clean and tight. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test: Start motorcycle, measure DC volts across the battery terminals you should have a reading of approximately 13.2-15 DC Volts.
3. Check Connections/Wires: Inspect the regulator/stator plug, and check the battery terminals for connection/corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC Output test Fails and Resistance Check, and Stator IB Test Pass then Rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Start motorcycle and change Voltmeter to AC volts.
Generic Specs:
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on system, check service manual for specification
Generic Specs:
Stator IB test or Ground Check:
If there is continuity to ground your stator is shorted to ground.
5. Regulator Test: Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Battery Charge Lead- Wire going from regulator to battery positive.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from regulator body to chassis ground).
Fwd/Reverse Bias Test/Diode Test: This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
My TTR230 won start plz help
What to Do Check When Dirt Bike Won Start
Yamaha ttr230 Service Manual
OEM parts for Yamaha
Yamaha TT R230 Owner Manual
Jun 18, 2012 | 2010 Yamaha TTR230
I have a 2001 Yamaha V-Star 1100 custom the battery goes dead while driving checked charging system all good?
Hi, Anonymous before testing any electrical component in the Charging System Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
5. AC Output Check:
Generic Specs:
Generic Specs:
Identifying Wires:
VStar charging problem
http://www.sloneservices.com/SilverBack/Other-Stuff/VS-1100-chagre-syst.pdf
Yamaha XVS1100 Service Manual
YAMAHA XVS1100 Owner Manual
May 06, 2012 | 2000 Yamaha V Star 1100 Custom
Teco AC displaying H5 error code... service mechanic looking for a hand
Try this link, as you didn't indicat what model you have. There are manuals in pdf form you can download. They will have a fault code listing if you can determine what model you have
http://www.tecowestinghouse.com/products/Drives/ga7200.html
Jul 03, 2010 | Inverter Yaskawa F7 Drive
It showes me on the xls60e fire panel ardesseble
An "earth fault" or ground fault is a condition where one of your circuits is grounded or shorted to earth. While all fire alarm systems are normally grounded for circuit board overload protection and personal safety issues, all circuits (bell circuit, smoke detector/heat detector/pull station circuits) should be free of earth grounds. I would suggest if you are not knowledgeable enough to troubleshoot your system you should contact a security/fire alarm installation company to fix the problem. If this is not a viable solution and you want to attempt this on your own try removing each circuit from the panel one at a time. While this will certainly cause additional system troubles, when you remove the circuit causing the earth fault the condition will disappear. You will then need to check all wiring, spice points and devices on that circuit to determine the faulted location.
Feb 03, 2010 | Honeywell Home Security
I have a fault code on a yaskawa varispeed f7 drive
Go to this link for manual.
http://www.e-mechatronics.com/en/product/inverter/f7/catalog.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 21, 2009 | Inverter Yaskawa F7 Drive
Nikon Optistation 7 Yaskawa Xu-rcm2500t-3 Robot Track Ost7-01-031-3 Working Logo
243 people viewed this question
Top Nikon Science & Laboratory Experts
Marvin
Marvin
matt
matt
Don A
Don A
Are you a Nikon Science and Laboratory Expert? Answer questions, earn points and help others
