Customer care support service number +1--833--[272]--0777,,,,,,,call them_______
This must be done before you ever put anything on the recovery partition d: , if you used d: for anything you need to remove what you put there or the recovery will not function.
Simple. Just remove the CMOS battery and the power from the pc. Wait for about 30 minutes. Plug in the power cable and power it on. The Pc will be passwordless. Setup your Windows and power it off. Place the CMOS battery back into socket and you are good to go.
Contact Dell yourself with information. They will not call you. You must contact them.
Read discussion below:
https://www.dell.com/community/Laptops-General/need-Dell-Inspiron-n4030-Bios-Password/td-p/4135000
need Dell Inspiron n4030 Bios Password
https://www.dell.com/community/Laptops-G...
SOURCE: Downgrade bios A07 to A02 of dell N4030 for
Never a good idea to downgrade BIOS revision. Could cause you to have to replace the system board if it doesn't install properly.
SOURCE: i have dell inspirion 1525
Find the service tag on the bottom of your laptop, and go to
www.bios-unlock.com you can get a password that will allow you to change the pw or disable this feature. Worked for me.
Good Luck
You may have to find the reset disk or may have to do a clean instal in which case is not fun however
If there was no passowrd created by you always remember to go the easies route >>> My advice look @ the operation manual if no luck then at that point you will have to >>>>> ; )
Dell XP = Ctrl+F11Dell Vista = F8
EEEPC = Esc
Compaq = F11
HP Desktop Vista = F11
Emachine = F10
Acer = Alt+F10
Every manufacture has or uses different Function Key combinations to do a Factory Default Recovery. Also if it didn't come with disks there is normally a program in the menus to create your own set of recovery CDs. This must be done before you ever put anything on the recovery partition d: , if you used d: for anything you need to remove what you put there or the recovery will not function.
