SOURCE: wavy lines on the screen and a high pitch sound
If you have a Dlp it might be the color wheel.The color wheel is in charge of creating the colors and when it's bad you'll hear humming,buzzing,whirling sounds.
SOURCE: lines are appearing on pictures
Please also try to upload new firmware: I doubt that it will solve the issue, but the alternative is a repair.
Connect the camera with the computer.
Turn the camera on.
Click onto the link and follow the instructions.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=10510/10543&product=EKN032940
SOURCE: There is a white horizotal
Your fault it known as "frame collapse" because the pictures frame has collapsed. It may be caused by a bad solder joint or a failed component. Not a problem for a TV engineer.
SOURCE: Scrambled picture on screen. Vertical
It needs to be reflowed. WE can fix it for $49.99. We are a listed repair service on this site.
www.videogamerepairservice.com
Let me start at the beginning---Likely a bad main board in your case but nothing is sure in this type of set.
Main board controls all information to the front screen and communicates to various boards---There really is almost never a simple "that part is bad solution" as any board, the power supply, the main, etc can cause issues.
It can even be a issue with the front screen unit--called a display panel.
You might consider doing some research on the set by Google of the model number with "parts" to get an idea what is available and what potential parts cost might be.
If a main board is bad it will average from one to two hundred just for the part----if issue is the panel you are done--part if even available is more than set cost when new.
Let me know if you have questions.
