Question about Hoover Vacuums
Hoover dual carpet washer will not turn on - Hoover Vacuums
    Sergeant:
  • 66 Answers
6ya staff
SOURCE:
reddevil6
Lauren Junge
  • 1673 Answers
SOURCE: I have a hoover steamvac
One cause is that the recovery tank lid isn't on correctly and not sealing. If there is a foam filter on the inside of the lid, make sure it has a 1/4 in. gap from the top of the lid. There is another filter, from the bottom, it has a red frame, pull it out far enough to clean it. May have a bad turbine, or the shaft on the top of the brush block broke off. You have a 1 years warranty on this, I would take it in to a warranty repair shop and get it repaired.
Posted on Aug 10, 2008
Anonymous
SOURCE: Hoover SteamVac Dual V Carpet Cleaner # F7410-900
"I did some research online and the recurrent theme was a bad turbine assembly. Fortunately I was able to fix this myself which took about 2 hours (some reading) and little effort. The problem was with the turbine which is fairly simple and had a bearing that had rusted and froze up. Removing the cover proved to be more difficult than fixing the stuck bearing. This was mostly due to figuring out the correct screws to remove and finally discovering that the back of the cover (over the wheels) is not secured by fasteners but by pegs that "pop" out.
Once I had the brush assembly and Cover removed the turbine came out with the removal of some obvious screws and gently pulling the hoses from the assembly. After carefully opening the assembly housing I discovered the bearing problem and with a little lubrication and some new grease had it working in short order. Putting everything back together was simple as well."
this worked for me. although once i got in i just had to mess around with the gears and loosen them up. getting in was the hard part soo here you go peoples.
take off tanks
unscrew 6 screws fom underneath machine. look carefully
just underneath where the dirty tank goes right by the part that sucks everything up is a screw. unscrew it
pop off the switch for your spin scrub mode. it pops right back on.
make sure your locks for the tank are turned in
then the back just pops off. you might have to give it a good tug. there are no screws although it maight look like there is.
then pull off the grey part.
once inside it is pretty easy.
but if you have any questionbs email at lostnhisblueyes@aol.com
i took off so many more screws than i needed to to get this figured out so dont do that.
Posted on Apr 03, 2009
rkintz
  • 190 Answers
SOURCE: HOOVER DUAL STEAM CARPET CLEANER BRUSHES WILL NOT
There are three things to check:
Is the switch on the hood for brush speed set to full, or may it be set to OFF?
Remove the brush block from under the unit by pulling it down and unlatch each side. Is there a 1/4 inch square drive pin on one brush, about two inches long? It connects the brush to the drive mechanism.
Lastly, the drive mechanism in the base may be bound-up, and not spinning. If so, the unit needs disassembled to repair or replace.
Posted on Oct 31, 2009
rkintz
  • 190 Answers
SOURCE: MY HOOVER DUAL V STEAM VAC CARPET CLEANER BRUSHES
Lastly, the drive mechanism in the base may be bound-up, and not spinning. If so, the unit needs disassembled to repair or replaced.
iandunn_tms
  • 168 Answers
SOURCE: hoover carpet cleaner dual 5
Try this site for more information on this problem
It may just need a good clean out.
http://hoover.com/support/manuals/?q=SteamVac
Posted on Feb 10, 2014
Free user manual for Hoover power path max
What is the model number of the carpet cleaner?
Home Depot has the manual for the Hoover Power Path Max FH51002 on the product page: https://www.homedepot.com/p/Hoover-Power-Path-Max-Upright-Carpet-Cleaner-FH51002/300984357 . The direct link to the manual is https://images.homedepot-static.com/catalog/pdfimages/e8/e81b1250-323a-4f1d-a23a-e4c319568399.pdf . In the manual, the model is called the Dual Power Path Max.
Hoover lists 3 Dual Power Path Max and 8 Power Path models on their manuals page: https://www.hoover.com/manual-video-search/ . The Power Path Max carpet cleaners do not show up with this search engine without adding Dual at the front of the search query.
I hope this helps.
Jun 23, 2018 | Hoover Vacuums
My Hoover Max extract dual v cleaner worked fine cleaning the carpet but when it came to using the hose attachment for my sofa, there was no suction and the brush did not spin.
Hello, Kathy -
If you have not yet checked your owner's manual; the Troubleshooting section, I suggest you do.
If you do not have the manual, you can download a PDF (Adobe Reader) version here:
https://www.manualslib.com/products/Hoover-Max-Extract-Dual-V-6126442.html
This is the link to the Troubleshooting section in the manual:
https://www.manualslib.com/manual/389163/Hoover-F7411900-Steamvac-Dual-V-Wide-Path-Deep-Carpet-Cleaner.html?page=19#manual
I hope you made sure the dirty water tank was empty and that the filter screen is clean.
Jan 02, 2018 | Hoover Vacuums
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
Hoover carpet cleaner dual 5
Feb 05, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Cannot remove handle from Hoover Dual-Power Carpet Washer
Cannot remove handle or release handle?
Release from the center pedal at the rear of the unit. Rove the handle with 2 long narrow bolts located near the half way point from handle grip to the base; don't loose the two small nuts or you'll have a bad time.
Nov 06, 2013 | Hoover F7425-900 SteamVac V2 Widepath...
Leaking Hoover Steamvac
Either you have a crack in the tank and it is running down the indise of the handle and going out the bottom, or there is a water line off either under where the tank sits or under the top cover.
Mar 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuums Logo
2,410 people viewed this question
Top Hoover Vacuums Experts
Kirk Thompson
Level 1 Expert
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
