SOURCE: brown staining of clothes,increased noise on spin cycle
that brown sludge is grease from the bearings and the noise is the bearings breaking up stop using the machine and get them replaced 2 supply and fit new bearings and drum support should nt cost more than £90 good luck not realy a job 4 a novice
Posted on Aug 06, 2007
SOURCE: self-cleaning leaves a brown stain on the white part on my oven
Perhaps the door gasket is not sealing well enough. In self clean mode the oven get very hot and vaporizes the fat off the sides. With a leak I think some of the fat is redepositing on on the outside where the leak is. You may need a new door seal.
Posted on Jan 30, 2009
SOURCE: When I use my self-cleaning on my oven it leaves a
Hello- The self-clean cycle heats the inside up to about 800deg. There is no existing plastic that can take the heat at the vent w/out discoloring. The stain is from the smoke produced when the stuff on the drip pan incinerates. Try some oxy-clean and a damp cloth. Try to predict or minimize spills with foil and drip pans. Techs call 'self-clean' the 'self-destruct' cycle. Using this function will reduce the life expectancy of any electric range. Let me know if this info helps-have more if needed- Thanks- ED
Posted on Mar 03, 2010
SOURCE: My glass cermamic cooktop is
try using a ceramic hob specific scraper to removed the burnt on bits then use a ceramic hob cleaner.
Can you let me know what country you are in and I can send you alternative links.
The following link are for the uk.
https://www.bosch-eshop.com/eshop/bosch/gb/ceramic-hob-cleaning-1.htm
311299 is the most cost effective as it contains cleaner and scraper.
Posted on Aug 21, 2010
SOURCE: Whirlpool Duet Washer/Dryer get brown streaks on clothing
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Mar 19, 2018 | Irons
Jan 30, 2018 | Irons
Feb 28, 2018 | KitchenAid 24 in. KUDS02FRSS Stainless...
Feb 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Jul 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Jun 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Jun 06, 2009 | Kenmore 44102 Front Load Washer
Mar 13, 2009 | Kenmore Refrigerators
Apr 01, 2008 | Rowenta DG-980 Iron
37 people viewed this question
