Question about The Toys
How to remove the battery box on a 245 massey ferguson
    Sergeant:
  • The Expert
  • 66 Answers
6ya staff
SOURCE:
Anonymous
SOURCE: massey ferguson 3655
sounds like the seals are gone on the 4wd shaft, it takes oil pressure to keep the 4wd off, but if the seals are worn the all passes through and the 4wd will not dissingage, you will need a experianced michanic
Posted on Apr 07, 2009
Anonymous
  • 86 Answers
SOURCE: Operator's manual for a Massey Ferguson 65 tractor
Go to google search engine and type in your tractor most of the time it will give you lots of web sites to look at.
Posted on May 12, 2009
Anonymous
SOURCE: What kind of oil goes in a Massey Ferguson Tractor
What model tractor - MF130/135 diesel takes 10/30 not gear oil for transmission/hydraulics
Posted on Nov 21, 2009
Robert Koch
  • 165 Answers
SOURCE: Massey Ferguson 35 has no spark, I have replaced
Test the plug wires, coil wire---could be the ends of the wires. Points could be burned and replace the condenser?
Posted on Feb 27, 2010
captjack163
captjack163
  • 13 Answers
SOURCE: What sort of oil is used in the gearbox of a
The Massey Ferguson's use the same oil as the N series tractors. 90W for the transmission.
Posted on May 01, 2010
Where can I find vin no on 1985 Massey Ferguson 250
Not to worry friend, when my machine go sick i avoided going to mechanic looking for DIY_Repair when I found this website https://big-manuals.com/ and this book helped me repair it within an hour, all by myself!!!
From wiring diagrams, schematic illustrations, spark plugs info, parts info, chassis number, valve time settings, step wise instructions, torque specs, error/fault codes, engine info, to every single minute parts, you get everything in there you can't imagine how detailed it is
Apr 14, 2018 | Heavy Machinery
How to remove the battery box on a 245 Massey Ferguson tractor
You will get your solution and all info on service info, repair info, parts info, wiring/electrical/fuse diagrams, error/fault codes, torque specs, PCV,
gear box, battery, troubleshootiing
owner's/service/repair/parts/maintenance manuals etc everything
this website www.reliable-store.com
it's a very good website for vehicle problems even as old as 1991 ford..
Mar 18, 2018 | Heavy Machinery
How do you wire Massey Ferguson 230 diesal ? With 3 wire delco alternator. Along with oil pressure switch , ammeter, neutral safty switch, fuel,water. 12 volts.
    mages for wire diagram Massey Ferguson 230 diesel
    More images for wire diagram Massey Ferguson 230 diesel
    230 MF - wiring diagram - SSB Tractor
    www.ssbtractor.com/wwwboard/view_all.cgi?bd=massey&msg=10416
    Allen Stewart, I need the wiring diagram of the dash area. Does anybody have this? Allen Stewart, wiring diagram is needed for Massey Ferguson 230 diesel.
    [PDF]MASSEY-FERGUSON - MyeDocs.com
Jan 01, 2016 | Toys
Massey fergason temp gauge diagram
Really is simple, wire comes from sender and connects at gauge. Some older tractors did not have gauges and even the holes for them had to be cut out of the dash face. Sensor wires were bimetal conduits and just transferred heat from motor to dash.
Jan 02, 2012 | RTO Massey-Ferguson Tractor TE20, TO20,...
Need a wiring diagram for a massey ferguson 135 tractor
I need a wiring diagram for my massey ferguson 135 tractor regards ****
Mar 24, 2009 | RTO Massey-Ferguson Tractor TE20, TO20,...
Toys Logo
59 people viewed this question
Top The Toys Experts
Paul Bade
Are you a The Toy Expert? Answer questions, earn points and help others
