SOURCE: Hydrostatic drive is weak
Try pulling back on the left foot pedal. This manually adjusts the drive belt tension and is a sign that the engine pulley has worn to the point the belt looses traction. A local repairman told me this last week and mine works fine now although in the very near future I'll need to replace the pully. Good luck
SOURCE: hydrostatic want pull hill
Either the belt is slipping in the pulleys ( replace belt ) or the hydro unit has internal wear, if this is the case as the unit gets hotter the issue will become worse due to the oil getting thinner and leaking internally, this would mean a hydro rebuild, or replacement unit
