Washing Machines Logo
M
Michael Leach Posted on Mar 18, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I repair the program selector knob on a Miele W 3204 washing machine which has been broken off flush with the control panel ?
Gao Mink
Level 2:
Sergeant:
  • Expert 66 Answers
  • Posted on Mar 19, 2018
Gao Mink
Expert
Level 2:
Sergeant:
Answers
66
Questions
Helped
12816
Points
973
5 Related Answers
Anonymous
  • 14 Answers
  • Posted on Nov 02, 2007
SOURCE: Program selector know is broken
First thing i would do if it is not selecting a different cycle is take the knob off and check to if the inside of the knob is broken and hust turning on the shaft, other then that it proberly is electronic replacement.
Anonymous
  • 5911 Answers
  • Posted on Apr 22, 2008
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
ginko
Ginko
  • 19396 Answers
  • Posted on Sep 30, 2008
SOURCE: miele dish washing machine no drain and it sudden stop after flushing the water
If the machine does not drain, then follow th suggestions below:
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
From repairclinic
Anonymous
  • 44 Answers
  • Posted on Mar 26, 2009
SOURCE: Program knob on GE washing machine not functioning
Older washing machines had a 2 position knob push or pull to set and the other position to run, also if the timer is bad it can be replaced the parts are still available on the Internet.
Have a good day...
Tim
Anonymous
  • 7 Answers
  • Posted on May 05, 2009
The teeth on the knob are gone. You need knob. Pull knob out (on pos.) look down on knob& in see clip push clip off to remove knob. Need screw driver
How to replace the WASH CYCLE SELECTOR KNOB - on an Ariston AV 105 Washing Machine
Replacing the wash cycle selector knob on an Ariston AV 105 washing machine can be done with the following steps:
  1. Turn off the washing machine and unplug it from the power source.
  2. Locate the wash cycle selector knob on the control panel of the washing machine.
  3. Remove the old wash cycle selector knob by pulling it straight off the control panel.
  4. Inspect the knob shaft to ensure that it is not damaged or worn. If the shaft is damaged, it may need to be replaced before installing the new knob.
  5. Align the new wash cycle selector knob onto the knob shaft, ensuring that it is fully seated.
  6. Push the new knob firmly onto the knob shaft until it clicks into place.
  7. Test the new wash cycle selector knob by turning it to different wash cycle settings to ensure that it is functioning correctly.
  8. Once you are satisfied that the new knob is working properly, plug the washing machine back into the power source and turn it on.
If you do not have a replacement knob, you can contact Ariston or a local appliance parts supplier to obtain the correct part. Make sure to have the model number and serial number of your washing machine on hand when ordering a replacement knob to ensure that you receive the correct part.
How do i remove the program selector knob from a hoover washing machine DYN9164DPG
To remove the program selector knob from a Hoover washing machine DYN9164DPG, please follow these steps:
  1. Unplug the washing machine from the power source.
  2. Locate the small metal tab located underneath the program selector knob.
  3. Use a flathead screwdriver to gently pry up the metal tab.
  4. Pull the program selector knob off the machine.
The metal tab acts as a locking mechanism to keep the knob in place, so be sure to pull the knob straight off the machine once the tab has been released. If you encounter any resistance, double-check that the metal tab is fully released before attempting to pull the knob off again. Once removed, you should be able to access and replace the selector switch.
Unable to find an english operating manual for a miele w822 washing m/c
Hi Dear. I assume this machine made for Nederlands - Dutch market. You can not obtain English manual for it. You may contact your local Miele center. They may able to supply you translated copy of user manual. Thanks.
Note: What I can understand from control panel, buttons from left to right : Door Button - On/Off - Pre -wash - Water Plus (adds more water)- Gentle wash and Short wash then Final spin speed selector.
Right hand side Program & wash temperature selector (Clock wise): Cottons - Minimum Iron - Delicate - Wool - Starch - Spin only - Pump only & Mini Program (Quick Wash)
Miele w844 washer has broken program selector knob and I dont know what cycle it is on. Is there a way to determine where the Finish point is without there being a knob on the machine.
Well, you could listen with a stethoscope for the timer to wind down.
Get a replacement knob on it; make a blank one if you like, and copy the marks on a knob from a (comparable) washer at a Miele distributor or repair place, relative to the flat or setscrew on the knob.Ah, so that's where it was.
1helpful
Hi i have an indesit w 123s washing machine, that set to any program it doesnt move on it just does that setting,then if you turn the machine off and set it to end program you can reset to rinse and the...
hello try restting it before you bin it
  1. Turn the washing machine off with the on off button.
  2. Turn the selector knob to a dot, or any off position
  3. Turn the washing machine back on and watch for rapid flashing on the neon light
  4. Turn the washing machine off and select the new program (or maybe spin)
  5. Turn it back on and the new program should start
NOTE: Resetting the timer selector knob as shown above may stop the clicking round, but if your washing machine has a fault, the clicking round may return when your washing machine encounters the fault again. If your washing machine's program selector knob is clicking round on its own, then read the section above Washing machine stops with lights flashing hope it helps
regards
shaun
Control knob snapped off.... wonderinff if this is an expensive repair. The washing machine is a miele m404 plus.
if it was just the knob no if it was the whole control yes very expensive the control arm cost around $ 300 but it would not damage it there must be more to this story if you simply need the knob - plastic control you can order it from here they cost around $ 30 www.meile.com
best of luck
3helpful
How do I remove the selector knob on washer
The main selector control know spins off by turning the selector inner knob counterclockwise. The outer ring will then pull off. The other knobs are held on with friction and should just pull off.
The best way to get behind the front panel is by removing the top panel of the machine. There should be 2 gray/solver tabs at the back of the machine near the top if you remove the 2/4 screws from the top then the whole top panel will slide forward then lift off.
Be sure to unplug the machine first.
2answers
Where can I buy Miele coffee system instruction book?
You have to buy descaling tablets from miele.  You turn the knob to program mode and keep pushing the enter button until you get to descaling.  You put two descaling tablets into your water reservoir and replace into unit.  Put containers under the steam valve and the hot water wand. Press enter.  Turn steam valve al the way on.  Keep an eye on the containers.  The process takes about 30 to 40 minutes.  The message will appear 'Descaling finished." Turn steam selector to O and press enter.  Display will read "rinse machine, fill watertank.  Fill tank and return to machine.  Place empty containers beneath hot water dispenser and steam nozzle again and turn steam selector fully on. Allow water to run through system completely.  When process is finished, display will read "Rinsing Finished."  Turn steam selector to O and press enter  Program selector is on Program Mode and display will read Descaling, Timrt, unit is no descaled and ready to use.  Turn program selector to on.
7helpful
2answers
Top Miele Washing Machines Experts
Paul Carew
vince
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
