Garden Logo
K
Kathy Gilkes Posted on Mar 18, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have replaced Part No. 574 694502 Arm, Idler 3 times over a period of 12 months due to the ARM cracking.
We have a Husqvarna RZ4221 Zero Turn Mower (purchased secondhand).We have around 1/2 acre of grass.
Gao Mink
Level 2:
Sergeant:
  • Expert 66 Answers
  • Posted on Mar 19, 2018
Gao Mink
Expert
Level 2:
Sergeant:
Answers
66
Questions
Helped
12812
Points
973
  • Kathy Gilkes
    Kathy Gilkes Mar 19, 2018
    Answer not related to question.
5 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Mar 20, 2009
SOURCE: Mixing Arm Doesn't Turn
As long as it makes the ice cream, it doesn't matter which one turns. If it's not making the ice cream, call Cuisinart, as both the lid and the mixing arm can be replaced.
-Tha Mp3 Doctor
Anonymous
  • 1201 Answers
  • Posted on Mar 24, 2009
SOURCE: Need pitman arm replaced and idler arm replaced
The idler isn't bad, Remove cotter pin going through the nut, take off nut, you need a seperator tool to pull apart the arm from the center link, once that is done, remove the two bolts holding it to the frame, remove arm, installation is just reverse.
The pitman arm is a little more to it. Do the same, remove cotter pin, take off nut, and seperate it from the rod, now there is big nut holding it on to the bottom of the steering box, take that nut off (some are a real pain), you will need a pitman arm puller to get it off. Note the position of the arm, need to put new one in same place, pull it off slow, sometimes seals will come with it, put seals back in same way, if they come out. Put some grease on splined shaft, tap new arm on until you can get nut on, tighten up with nut. Hopefully you have any problems. Good luck.
Anonymous
  • 678 Answers
  • Posted on Apr 17, 2009
SOURCE: Replace idler arm pulley
An idler arm is a steering component found on vehicles without rack and pinion steering. Your referring to an idler pulley. To replace: remove the belt, remove the bolt from the center of the pulley, replace the pulley and reinstall the belt.
Anonymous
  • 61 Answers
  • Posted on May 05, 2009
SOURCE: replace idler arm/pitman arm
Don't worry it is not too hard if you keep at. One "special tool" that you will need is a ball joint separator to separate the ball joint on the idler arm from the steering. When changing make sure to compare your replacement parts with the original and if necessary make a diagram of how things go together. On the bottom, there is a castle nut and a cotter pin. Remove the pin and loosen the nut then use the ball joint separator to remove the idler arm. (This is the hardest part of the job.) Then remove the remaining bolts and take the part off. Before putting the new idler arm make sure that you put the new grease fitting on it (and go ahead and squirt a little grease in it even though it already has some) and in between the new ball joint and the steering there should be a plastic bearing that slips into place. It's a pretty straight forward job and once you take a good look at it you will see what all needs to be done. Hope this helps, let me know how it goes. Goodluck!
cy schousboe
  • 2002 Answers
  • Posted on Jul 08, 2009
SOURCE: repair steering linkage
You'll have to rent or borrow a pickle fork and a pitman arm puller. There is more than one size of pickle fork so specify for tie rod ends. You can buy them too, about $100 for the pair and they are not vehicle specific.
Jack and block up your front end so the wheels are clear. Take the nut off the tie rod end and wedge the pickle fork between the tie rod and the drag link, rap with a hammer until it separates. Loosen the bolt on the collar and unscrew the tie rod end. Count the turns when you remove it and screw the new one in the same number of turns.Fit it into the drag link and tighten the collar and the new nut.
Take the nut off the idler arm and use the pickle fork to separate it from the drag link. Unbolt the idler arm from the frame. The new one goes on in the reverse.
You'll probably need an adjustable wrench to remove the nut from the pitman arm,it's bigger than most wrench sets. Separate it from the drag link first. Slide the puller on and tighten it up. Once it starts to turn hard, give the bolt on the puller a rap with the hammer and tighten some more. Repeat until the arm comes off. Slip the new one on and tighten.
Don't be shy when you tighten these parts because if there is play, the holes in the drag link will oval out and you will have to replace it too. Don,t use a pickle fork on the pitman arm or you will have to replace the seal in the bottom of the steering box. Hope this helps.
2answers
Husqvarna MZ48 zero turn dies when either arm engaged but mower blades run without issue
Did you disengage the brake. I sometimes forget to disengage the brake but when the engine starts to shut off i realize that I did not disengage the brake.
How can i loosen a stiff right drive arm on my Husqvarna Z254F zero turn mower?
Try disconnecting the damper (small shock absorber) and see if symptoms change.
Cub cadet m60-kh the PTO belt keeps jumping off
https://www.partstree.com/parts/cub-cadet/mowers-zero-turn-lawn-mower/m60-kh-53ab5bdx750-cub-cadet-commercial-tank-zero-turn-mower-27-hp-kohler/fabricated-deck-spindle-assembly/
Likely the deck idler pulley is loose or bearings are shot. The pulley should not wobble and the flat side of the belt should ride square against the pulley face (the pulley should be reasonably perpendicular to the deck). If not, the idler arm pivot is loose or the pivot bolt and arm are shot. Check proper tension is applied by idler pulley torsion spring (the belt is not loose).
c1-rh14230rqgibnrzrzz3yshgm-3-5.png Comment here and Ill assist further if need be.
How to reinsta l idler pulley arm
Commercial Mower Maintenance-Replacing Idler Pulley ...
? 3:44
www.youtube.com/watch?v=io2aCjM0o8Y
Sep 30, 2011 - Uploaded by askanthonynow
After new bearings were placed into an idler pulley, it is being installed on the deck of the mower. This is the .
How to Replace the Deck Idler Pulley on a Troy-Bilt Pony ...? 8:04www.youtube.com/watch?v=HY9AuNe5DWAAug 13, 2013 - Uploaded by eReplacementParts.comThis tutorial will show you how to remove and install the idler(4.25") pulley on a Troy-Bilt Pony lawn tractor/riding mower. Helpful items include ...How to Fix the Idler Spring on a Zero-Turn Mower ' Home ...
1helpful
How do i replace drive belt on husqvarna zero turn model#96645580
To replace EZT belt
Park the mower on a level surface. Engage the park brake.
EZT belt removal
NOTE: Be careful not to damage the fan blades on the EZT as this can affect cooling or damage the EZT.
  1. Remove the deck belt
  2. Create slack in the belt by pushing the spring loaded idler arm away from the belt.
  3. Rotate arm to release belt tension.
  4. The belt should now be able to be removed from the engine pulley and EZT pulleys.
Belt installation
  1. Wrap the EZT belt around the EZT pulleys.
  2. Wrap the belt around the engine pulley.
  3. Route the belt around the inside of the idler pulley while keeping tension off the belt and then slowly the idler assembly afterwards.
  4. Check that the belt is on all the pulleys correctly and test drive your unit.
  5. Afterward then re-install your mower deck once your are satisfied with the drive installation..
2answers
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Do they make a husqvarna zero turn Motion arm extender
no but the arms are adjustable... having an issue hitting reverse by chance ???
Tension spring keeps breaking on deck idler pulley
The same thing has happened to me, twice. The Idler arm bracket has broken in the exact same spot.
2helpful
Mower starts, but won't move forward. I found torn belt underneath. I'm assuming this is a drive belt (are there two--one for each wheel). How do I change it out. (Best way to lift a zero turn?).
First, wedge something in front of the front wheels (when you lift the back, there's no brake action). Get the jack from your car and position it to lift the rear of the mower chassis. Jack it up then put blocks under the rear wheels - you may be able to do both at once, or you may have to alternate - then lower onto the blocks. Get enough space. You'll have to take off the mower belt and remove the PTO clutch anchor (two bolts) and may have to take off the wires connected to the PTO clutch (connector may be above the chassis). Then pull off the spring that tightens the idler arm, remove the old belt (if it's still there) and install the new one. Refasten the spring to tighten the idler, replace the anchor and mower belt, and mow away. Good luck! Please rate my answer if helpful, thanks.
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
