Question about Maytag Kitchen Ranges
My Maytag electric oven will not heat up over 100 degrees, please help
    Sergeant:
  • 66 Answers
Posted on Mar 19, 2018
6ya staff
SOURCE:
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: oven slow to heat
In alot of ovens preheat will cause the both the broil and bake element to come on. You are most likely getting heat from the broil element. This means either the bake element is bad or the relay on the oven control is bad. If the element shows resistance with an ohm meter then replace the oven control board.
Posted on Oct 06, 2007
Anonymous
SOURCE: electric oven does not heat up enough
I had the same problem before the warranty expired. The heating element had exploded and there was white powder all over the inside of the oven. They replaced the heating element and it works as it should, however, this oven has never baked right. It gets hotter on the right hand side than it does the left and I have to constantly watch whatever I bake. I'm not very happy with this oven.
Posted on Jan 18, 2009
Anonymous
  • 85 Answers
SOURCE: We have a Maytag Gas Range, Precision Touch
Likely your oven igniter is bad. Part number 74007498
Posted on May 18, 2009
Anonymous
  • 85 Answers
SOURCE: maytog gas oven model 5765QDB--oven will not heat up
Sounds like your oven igniter is bad.
Part number is 74007498
EllaWatson25
Ella Watson
  • 725 Answers
SOURCE: My Maytag electric oven will not heat beyond a
Your temperature control has gone out and this is simple repair!!
Posted on Oct 20, 2009
Maytag gemini wiont go over 100 degrees
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Apr 03, 2011 | Ovens
My Maytag Gemini double oven gas...........the bottom oven won't heat up past 100 degrees. What can I do to troubleshoot?
Hi
This issue seems to be with the gas inlet valve or the igniter itself that is bad. Gas Valve has a bi-metal that open when a certain amount of current flows through it to heat it up. Make sure that the glow bar is not cracked. Faulty igniters can allow correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. Hope this helps... Please post back if you need more information.
Daniel
Jan 18, 2011 | Maytag Gemini 30" Self-Cleaning...
I have a maytag MER6772 electric rage and the bottom oven will not heat past 100 degrees. the top heat to 350 then's cuts off. I replace the Control board wahts next?
The board cannot function if the sensor is bad. You should always check a sensor first.themobilian_898.jpgthemobilian_899.jpgthemobilian_900.jpg
Use this chart to check the sensor.
This video shows how to check:
I have some manuals and error codes posted HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 15, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Oct 20, 2009 | Maytag 30" Built-In Single Electric Wall...
I have to adjust my oven temperature with an oven thermometer. I have to set the oven higher to get to the temperature I want. It's sometimes as much as 100 degrees lower than the setting. To get it to 350...
Oven temp sensor failure, possible control board problem. Unit thinks its a different temp. sensor connects directly to control....suggest you to call maytag cust service....sometimes they will assist with parts
Jun 09, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Mer5875QAS electric range won't heat
Maybe bake element is bad or bake relay on board is bad.
Nov 05, 2017 | Maytag MER5875QAS Electric Kitchen Range
Why won't my Maytag electric oven heat past 210 degrees?
Hello could be oven thermostat,when you are sure of the part you need check out www.appliancepartssolutions.com cheep parts!
good luck
Apr 08, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
Maytag MER5870 Electric Kitchen Range
Hello ppeaches,
Are you sure that the oven isn't heating up more than 100 degrees or are you basing the problem on the ovens readback of 100 degrees? If it truly isn't heating more than 100 degrees then anything inside there should be hot but not so hot as that it can't be touched. Have you tried to cook anything in there? My intent to assist in diagnosing the problem is to determine if it is a control based or read back based issue? Try cooking something that requires at least a 350 degree temp and get back to me on what happens... We;ll get you running after that,,,,,
Sep 22, 2008 | Maytag MER5870 Electric Kitchen Range
Kitchen Ranges Logo
346 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Marvin
Marvin
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
