I watch movies useing silk browser on my fire stick tv but sometime when i am watching a movies it stops every few seconds what can i do to stop that
    Sergeant:
  • 66 Answers
Posted on Mar 19, 2018
Anonymous
SOURCE:
Anonymous
  • 33 Answers
SOURCE: The channel information/display won't stop popping up every few seconds.
What you all need to do is get away from a coax cable connection. If you have a cable box, or satellite box, take the coax cable off and use red, white, n yellow rca composite cables to connect your recievers to the tv. if you dont have a cable box, either get one, or get a converter box and use a tuner outside of the tuner within the unit. The tuners in those tv's are built to show you when you experience signal fluctation(which is normal with a coax cable) and thats why the box keeps popping up on its own. good louck to you all with this problem
Posted on Feb 19, 2009
Anonymous
SOURCE: My watch constantly stops
check for automatic winding offcentre disc clutch mechanisum fault
Posted on Aug 24, 2009
Anonymous
SOURCE: Guess Watch's stop watch is broken?
it's not broken.
let's call the top stopwatch button "a" and the bottom stopwatch button "b." eg, for normal stop watch function press "a" to start timing, press "a" to stop timing, and press "b" to reset.
to reset: press button "a" and "b" simultaneously and release (an easy way to do this is press and hold down "b" then press "a" and release both). this will send both hands spinning. next press "a" intermittently until the second-hand is back to it's desired reset location. then, likewise, press "b" intermittently until the minute hand is zeroed. now with both hands at the correct reset location, again press and release "a" and "b" simultaneously to save these resets and return the watch to normal function mode.
Posted on Oct 07, 2009
Anonymous
SOURCE: The second hand of my Tissot watch T870/970 starts and stops.
Hello!
Absolutely astonished by this "solution" from escapement.
This watch is working perfectly - it is simply giving its "end of battery life warning".
Posted on Dec 11, 2009
Anonymous
  • 3 Answers
SOURCE: seiko watch stop watch needs resetting
You can download an instruction manual for your watch here. It will detail how to reset the hands. :)
Tom
Posted on Jan 03, 2010
Is there a better browser for the Amazon Fire Stick than Chrome?Chrome isn't easy to use and get around web pages.
Yes, there is a better browser. If you have the first or second generation Fire Stick, use the Silk browser. The browser is an Amazon browser made specifically for the Fire TV Stick. Silk Web Browser for the Amazon Fire TV Stick Low Tech Grandma
Dec 12, 2017 | Televison & Video
How do I stop the fire stick from locking up when watch a program?
If You are powering the stick from the USB port on TV, You need to plug the power to stick from the wall plugin using adapter instead of TV's USB port. The port in most cases does not have enough power to run the stick! This will cause the stick to stop performing restart or freeze up!
Jul 13, 2017 | Televison & Video
With my fire tv stick
Here is a link that is to Amazon Device Support. Choose your device, and follow the links, suggestions, or contact options!
https://www.amazon.com/gp/help/customer/display.html/ref=hp_ss_v3_ds_t4?ie=UTF8&nodeId=200127470
Apr 07, 2017 | Amazon Fire TV Stick
Connect my amazon fire tv stick
The stick will only work with a tv with an hdmi port.
Jul 12, 2016 | Amazon Fire TV Stick
Watch stops after wearing for a few hours
Self winding watches need motion ( wrist twist) without they can stop. Sometimes just shake your wrist for a few seconds. I purchased a winder box for times I don't wear. ( Amazon)!
it is belt driven winder, rotates watch 5 minutes every hour.
Apr 21, 2015 | Rolex Submariner Oyster Watch for Men
When watching tv using my fire stick the movie always stops and it says I have a slow internet connection or says my internet bandwidth is to slow how can I fix this,
Get faster internet. The firestick is slow , not meant for streaming videos at all. Trust me, I'm a Jedi.
Get better service if you're going to stream
Mar 04, 2015 | Computers & Internet
Watch stops working after a few seconds
Give it up. I have tried to repair some watches that simply refused to revive. The movement may be no good.
Oct 17, 2017 | Jules Jurgensen 3302DS ( ) : Swiss Quartz...
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
