Question about Dishwashers
Door drops down with no resistance on Lamont integrated dishwasher.
    Sergeant:
  • 66 Answers
Posted on Mar 19, 2018
  • Larry Mar 19, 2018
    WHY all a sudden are we getting people posting totally nonsense answers and doing it hundreds of times a day, some have even been links to sites that have viruses...isn't there something that can be done with these people????
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: neff integrated dishwasher
there are some screws inside the door, around the edge. These would be the first to undo then I think the door would have o be pulled up slightly to relaease.
Posted on May 05, 2008
Chris C
  • 4 Answers
SOURCE: Hoover dishwasher door
A metal bad with a spring on each end is used to couner balance the door. Take off the curved plastic moulding at the front bottom 2 screws at front and 2 underneath.
Then remove as many screws as you can that secures the left hand casing you just need to get to left hand side near the bottom.
Once there you can check if both springs are secure it is probable that one of these has become dislodged you can get some pliers and bend the hooks better so that it will not happen again.
Posted on Mar 02, 2009
How can I clean the inside of the glass on a Lamont 3400 oven door
Hello, Johnny -
The instructions I found for cleaning the glass inside an oven door are generic and not just for a Lamona brand oven. (You did mean "Lamona" and not "Lamont", didn't you?)
See the instructions here:
https://www.mom4real.com/how-to-clean-in-between-glass-on-your/
Read through the instructions, in full, first.
This is a link to other instructions in video format:
https://www.todayshomeowner.com/video/how-to-clean-inside-the-glass-on-an-oven-door/
Best wishes.
Mar 07, 2018 | Ovens
Flap on tablet dispenser on Lamont dishwasher won't open
Totally stuck or can you open manually?
I suspect you can open by hand, but sometimes overloading can result in jamming.
Should be spring actuated after a solenoid release.
If all is well mutually, sounds like a service call to take the door panel apart and troubleshoot.
if so inclined, you can find an exploded view of your unit on a parts supplier site and, exercising usual cautions, explore yourself.
Oct 23, 2016 | Dishwashers
How do I adjust the door opening on my integrated dishwasher ?
The door springs are too tight. Please provide model number so that I can find the instructions to adjust the door springs.
Jul 30, 2014 | Tecnik Dishwashers
How to remove door to an integrated dishwasher
Good Morning Friend,
I understand that you want to remove the door to your integrated dishwasher, model# ESL6114. This appears to be a UK Electrolux dishwasher. I suggest contacting the manufacturer directly. They will be able to better assist you in removing your dishwasher door.
-Best Regards-
WP
May 20, 2014 | Electrolux 23 in. ESL6114 Built-in...
Dishwasher door drops suddenly on opening
Most likely one side or the other has a bolt or fastener that gave away. You will have to take the door off to see what is going on in there by the hinge point.
Jan 11, 2014 | Electrolux EDW5505ESS Built-in Dishwasher
The door of my Miele G646 SCI semi-integrated dishwasher has suddenly become stiff to move up or down. I am guessing there is a problem with the spring? Any suggestions what to try or how to get access?
Most probably the decor door has swollen and catching on adjoining cabinets. removed decor door via two screws down the left and right hand side of door and see if that helps. If springs snaps then the door will drop very quickly and take the skin off you shins
Jan 14, 2011 | Miele 24 in. G646SCi Plus Free-standing...
Smeg integrated dishwasher continually washing - won't move to drying cycle.
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Nov 02, 2009 | Smeg STA4645U 18" Fully Integrated...
Neff dishwasher removal
this may work - if it is an integrated dishwasher you should have a star shaped screw attaching the door to the machine on either side (about half way down). try pulling the machine out - and then looking for the holes on either side at the front. insert a star screw driver (may not work with other screwdrivers) and release the bolts (screws) then slide the door upwards.
Jan 17, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Neff integrated dishwasher
Mar 28, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwashers Logo
51 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
