Tv... picture and sound break up at 12mins to every hour ...last about 4secs ie... 10.48...11.48..12.48..etc
    Sergeant:
  • 66 Answers
Posted on Mar 19, 2018
6ya staff
SOURCE:
Video monitor
you connected the sound via optical spdif .......if the reciever has HDMI use that if not....select the correct device by going through the receivers selector .....ie: AV, DVD, CD, etc etc...you will find the picture when doing this. should work, also ensure the Tv source has been correctly set as the "SOURCE" on the tv remote.
Feb 03, 2014 | Kenwood VR-409 Receiver
Akai tv picture no sound
If picture is OK, sound should be there. Check the settings to sound first, ie, 'system' 'mute' etc, by entering the sound menu. If an improper system is selected, the sound will be either absent or distorted. If all the other settings are OK, and still there is no sound, you have to check the audio output section circuit, speakers etc?
Jul 19, 2013 | Televison & Video
Sony KDL-40bx450 no sound
Two things to do:
First see if you have sound with a DVD etc connected to a rear input.
Second look in the menu to make sure speakers not switched off or to external
Dec 13, 2012 | Sony KDL40BX450 40" 1080p LCD TV...
Tv turns on got goog picture then after an hour it turn picture off but still have sound
Going to be a shop repair as when lose picture someone has to check voltages etc to see where the problem is at.
Aug 29, 2012 | RCA R52WM24 52" HDTV Projection Television
Lost picture
When was the last time u replaced the projection bulb,yes it could be that simple the projection bulb it dead.The bulb last only about 1 or 2 years,by using the tv on about 4 or 5 hours a day.
Jun 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Have flat panel hdtv monitor 1080i samsung no picture or sound
Tv has no picture or sound; will go out while watching. The picture will go into a line and sound and picture will go out; shortly after that tv will turn off. Did this last nite and I did not turn back on until this morning, it worked no problem. On for couple of hours and now it's out again. What could be problem and how do I fix myself
Feb 27, 2010 | Televison & Video
Picture goes out - but has sound
i have had this problem on one of my tv s all i did was remove the back of the tv and re-solder all the joints around the tuner (thats where the arieal goes) they go with time because the joints there get so hot . hope this helps
puggy
Jul 07, 2009 | Televison & Video
No picture at all,sound ok 3 tube crts off after 4secs when on
might be a crooked flyback transformer, first check for shorted transistors around the transformer and components at the horizontal output stage..
Mar 31, 2009 | Philips Televison & Video
Problem setting up DVD home theatet sound system sc-pt460 with my vierra panasonic TV. The two appropriately connected with HDMI plus Optical cables. Mainly wish to use it improve TV sound. Have got it...
to see the dvd sound menu option you must be on the correct input selection for your tv. ie. if its Scart, then AV1, or if HD then HDMI 1 etc. then you see the options. as for sound being variable, you can adjust the sound for each speaker in this mode. Main thing for having surround sound with normal TV is to turn on the sound enhancement mode. also, on your viera link on the tv remote, make sure sound its selected as home cinema. word of warning, leave dvd on D-In option, and when turning the TV off, use standby mode, which turns both systems off, ensuring the link does not break.
Aug 18, 2008 | Panasonic Televison & Video
Problems connecting computer to tv via dvi
Not sure if you have fixed your problem or not. When I hook up my pc to the ILO 32 HD...I ran DVI input for picture...you can also use HDMI if you like..I had a problem with sound and had to use a splitter and run sound into AV2 IN to get sound for some reason...your no picture...if you are getting a black screen, you need to set the resolution on your pc. VGA to 640x480 and SVGA should be 800x600 and XGA should set at 1024x768..most likely the last one is the one you need..and this is not a normal pc res....set your refresh rate to 60HZ. All this is done in the control panel/display/settings tab. Also remember that you need to change your source on the TV to the proper connection to see it...ie component, HDMI etc.
Apr 02, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
