The TXB2025 is an other tv using crt... unless Samsung has reused model numbers from older tv's, your best bet if you have a vcr or dvd player with composite inputs "RCA" then you could use a roku connected through the vcr/dvd unit as i dont believe they had any inputs on them other then coaxial, if you got the model number wrong and in fact talking about a newer smart tv you should have Netflix app built in or you can also use a roku and get Netflix, Hulu, PBS and others
SOURCE: old tv samsung txb2025
On your remote control, find F-SET.
After clicking that, you'll see choices, including TV/CATV ... there are three choices there, you want STD or HRC. That should get you the main cable channels that do not require a box.
SOURCE: netflix problems
maybe this can help. If not, please supply your TV model.
You need to register with Netflix online first to create a login and password.
Here`s how to:
>> On your computer go to netflix.com then click signup or signup.netflix.com
>> Fill all the necessary information they needed.
>> Purchase any plan they offer after you created an account(Optional as you can avail a trial version for 7 days)
Now go to your TV
>> Turn the TV on then hit menu
>> Go to My apps menu
>> Select Netflix
>> Sign in with your username and password
>> Take note of the code
>> Go to your computer and login to netflix.com/activate and type in the code to activate.
>> Go back to the TV select finish to start the service
Important:
Make sure your TV is connected to the internet, either wired or wireless
Here are the three methods to connect wireless on your TV:
Scan and connect
>> Turn on the TV
>> Go to Menu
>> Go to Network settings
>> Select easy then scan for networks
>> Select and connect
Connect using WPS
Press the WPS button(Padlock with signal wave) on your TV`s side panel then on your router.
Note:
You only have two minutes before the router turn the WPS off
Add network manually
>> Go to Menu
>> Select manually add network
Type and select the appropriate settings:
SSID: Name or the Wireless network
Security: Either the WEP, WPA, WPA2 or WPA+WPA2
Passphrase/Passkey: Type in the password
Wait for a prompt that the TV is connected to the internet.
You can buy a Blu ray player that has net flex on it. Then what ever TV you hook the player to you will have net flex but, you have to pay a monthly bill for net flex.
SOURCE: 46" Samsung smart TV series 5, purchased Nov 7
It sounds that the the problem is with its firmware. It will be best to consult the authorized service centre for Samsung, before doing any software update. A software update will be necessary. But, without knowing any details about the version of software loaded at present, it is difficult to advice you more about the software version, which has to be updated. A wrong software update might make the TV fully in-operative. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Have you tried using an Xbox Wii or Ps with your tv, cuz some TVs with build in Wi-Fi just never work right. Also plug it straight in to your router check in settings for an update, good luck
