My drain hose on back of lg front load machine leaks as it fills with water.
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
SOURCE: Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
SOURCE: LG WM2487 front load washer spews suds out of port on rear.
You are likely using too much detergent or the detergent is not high-efficiency detergent. Change detergents and/or lower amount and this problem should go away.
The water port on the back allows air inside the tub to escape. However, if the wrong type or quantity of detergent are used, excess suds will flow from this port.
SOURCE: LG front load washer OE error. cleaned filter need
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!
