Situation:
Notes:
What to Do:
SOURCE: error code SC542, unable to clear message from
this is an error for the fuser heat up..the temp is not being maintained or fluctuations. try this press the yellow clear button at top of number pad then enter 107 and hold down the red cancel button..the screen will change enter the copier sp and select 5.mode arrow down to 5-810 sc reset and execute.turn machine off.. if the code disappears it could have been just a glitch if not check the fuser to see if there is heat coming from it the lamps will come on at te start up. you can check this by putting a screw driver in the actuator slot to cheat the door switch if you see the lamp come on then you may just have to clean off the thermistors .. open the fuser up with the top screws and check that there isnt any build up of toner on thermistors..hope this helps good luck A
SOURCE: Nintendo wii points card, how can we get card
You have to call Nintendo of America @ 1-800-255-3700. When you talk to a representative they will take information from you including the your Wii serial #, the control # on the card and your personal information. Once they have all of that, you will be told to mail the card along with a letter re-stating everything that you have already told them and they will get back to you in 24 hrs within receiving the card....
SOURCE: We bought a Nintendo Points
Welcome to Fixya. The best person or department that can help you with this is the Nintendo Support they have the information of the card and they can provide the information that you needed to fix this.
Nintendo Support
You can inform then about the card and hopefully they can provide the 4 digit that is missing. They can also check if the card is already used or not.
Thanks
SOURCE: wen i started to scratch
If you call nintendo customer support at 1-800-255-3700 if you have the card handy it should have another number on the back that they will ask for to verify the purchase otherwise they may need info from the receipt of purchase to get you a new one or new number for the card.
Good luck and happy gaming!
William
