It sounds like you are having trouble getting the lid on your Maytag Bravo top-load washer to close properly, even after replacing the lid strike and the lid latch. There could be a few reasons for this issue:
- The lid strike and latch are not properly aligned: Make sure that the lid strike and latch are properly aligned and that the strike is lined up correctly with the latch.
- The lid strike is not adjusted correctly: The lid strike may need to be adjusted in order to properly engage the latch. Check the installation instructions for the strike to see if there are any adjustment instructions.
- The lid latch is in lock mode: Some Maytag Bravo top-load washers have a lock mode that prevents the lid from being opened during a wash cycle. Make sure that the latch is not in lock mode by checking the owner's manual for instructions on how to unlock the latch.
- The lid strike or latch are defective: If you've tried the above steps and the lid still won't close, the new strike or latch may be defective. It's recommended to contact the manufacturer for further assistance or to contact a professional technician for repair.
It's important to make sure that the lid is closed properly before starting a wash cycle to prevent water from leaking out of the washer.
