Mower starts, dies quickly. Replaced needle and seat. can you help ? has 43 lbs compression
Did you clean the carb's small orifices when you installed the needle/seat ?
Sounds like it's getting no fuel.
Try spraying a flammable carb cleaner into the carb after removing the air filter. If it will run as long as you spray the cleaner, it's something in the carb.
Your 43psi compression could be your compression release for easy starting of the engine. It kicks out when the rpm goes up and gives full compression.
Since it does run, just not very long, I think your issue is just gas delivery to the engine i.e. something is plugged up in the carb.
Testimonial: "Thank all for your input."
SOURCE: tecumseh 2 cycle snowblower
I know this may sound stupid but I've don it my self is the gas on? If it is then my next ? is, does the nut on the bottom of the bowl have an adjustment screw in it? If it does see if it is turned in all the way, if it's turned in than from just bottom out turn it out 1 1/4 turns out that is the fuel flow needle once running that needle may need to be fine tuned,also if it is turned out to far it wont run either cause it will flood out. If that doesn't work it might be something internal with the carb.let me know how you make out and if we need to check into it further.
SOURCE: I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
SOURCE: Craftsman 550 brand new mower wont start
14hp 38" Craftsman rider model 917.255470-While riding it just died. found wire skinned going to the solenoid on caburator bowel. Thoght that was the fix-still won't start-any suggestions.
SOURCE: I have a Craftsman 650 series lawn mower. It
I have a similar issue in that my Craftsman 650 in that it sputters and smokes out of the muffler and spits oil out from there as well. It does not die, but I cannot operate the lawn mower with all the smoke and oil blowing out. Plus, I get oil leakage on the deck of the lawn mower (top). What would I check for here?
SOURCE: STARTS GOOD BUT ENGINE DIES WHEN CLUTCH RELEASED
cut the wires running to the switch...try again...if same, stripp back wires, and twist together...wrap in tape or use some sort of connector...it's electric and should be treated as such...try again...still ?? Start finding those switches and repeat the process til it works...theres usually 3 or 4...
Testimonial: "Haven't tried the suggested solution but makes sense."
