SOURCE: How do you set up wireless printing w/the canon PIXMA MX700?
Hi Coach!
Here is a tutorial that will explain most of the basic steps to sharing your printer. It will walk you thru how to set it up.
With the Canon, MX700, on each machine you connect to the printer, you will have to have the driver CD. When XP asks for the drivers, just put the CD, and XP will find it drives it need. This whole process will go smoother, if you use a printer cable and not the USB. If you need the drivers, you can get them on the Canon site.
Good luck,
http://www.pcstats.com/articleview.cfm?articleID=1596
SOURCE: Wireless Printing set up
In order to print via Bluetooth communication with Macintosh, the following system requirements must be satisfied.
Computer
A Macintosh with an internal Apple Bluetooth module or a Macintosh attached D-LINK DBT-120 USB Bluetooth rev.B
OS
Mac OS X v.10.3.3 or later
In order to connect the Bluetooth unit and print via Bluetooth communication, the following steps are required.
STEP 1
Check that the Bluetooth unit is properly attached to the printer.
STEP 2
Install the MP Drivers.
STEP 3
Check the device name of the printer using the LCD.
STEP 4
Register the printer as a Bluetooth device using Bluetooth Setup Assistant.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
