Question about Science & Laboratory
Twinning under microscope - Science & Laboratory
Good afternoon. I bought a Deluxe Digital
Hello, Have you tried putting something under the microscope and then trying to focus on it?Maybe the lens is out of focus. See if there's nothing obstructing the lens. If problem persists after trying those two things you should probably send it to warranty as there most likely is a bad connection between the lcd and the camera.
Hope you can fix it easily.Best regards Vlad
Dec 01, 2011 | Celestron 44345 Microscope
What is the other types of microscope ? how do they differ from a compound microscope ?
Compound Microscope
  • Compound microscopes can be found in most biology and science classrooms. They are electrically operated and use light to enhance the image of a cell. They will have multiple lenses for viewing.
Dissecting Microscope
  • Dissecting microscopes are also known as stereo microscopes. They have low magnification and are also light powered. These microscopes can view objects larger than what a compound microscope is able to handle, in three dimensions.
SEM
  • A Scanning Electron Microscope uses electrons instead of light to create an image. These microscopes produce three-dimensional images with high resolution and magnification. They also have a larger depth of focus.
TEM
  • Transmission Electron Microscopes use electrons instead of light to create an image. The material prepared must be very thin. The beams of electrons that pass through it give the viewer high magnification and resolution. These give two-dimensional images.
Jul 03, 2011 | Computers & Internet
My microscope is focused on an object on the slide but not the object I am to observe. What is the possible problem?
You must move the slide so that the "Sample" is "Under: the object lens...Or move the sample so it is directly under the object lens, the sample must be right in the "Middle" of the "Slide" the sample is on.
Mar 01, 2010 | Science & Laboratory
We are receiving the following error message "No Video capture Device detected: We have reinstalled the softwar, ensured the microscope is connected as instructed. Appreciate id we can get some assistance....
With the computer off, turn the microscope camera on, then turn the computer on. If it still doesn't work, then it's likely that the drivers aren't suited to the OS, in which case you chould be contacting Motic to get the right drivers for your OS. (There are several known issues with Vista and Windows 7 and those microscopes)
Feb 17, 2010 | Motic DMB5 Binocular Microscope
My microscope won't focus, i tried everything...i don't know what is wrong with it...it's brand new.. it worked a couple times but now it just stopped.. i dont know what brand it is...all it says is...
If your stage is still in its correct orientation then make sure your objective lenses are screwed in tight as well as the eye piece being secured correctly. Try using different objectives (don't go too high or you may damage your lenses if you ram it into your specimen) and using the fine and course focus. If the you still cant focus using different objectives it's quite possible that your mirrors or lenses inside the microscope have been knocked loose. I would then recommend only having it repaired by a certified microscope technician. If it is still under warranty take it back to the store of purchase or send it back to the manufacturer.
Jan 04, 2010 | Science & Laboratory
I have about 10 microscopes in my classroom. Each of them light-up, adjust and appear to work ok. The problem is that you can't see what is on a slide. When I put the same slide under a newer scope I can...
Classroom scopes get dirty very fast. This can cause the images to look dim and faded. Contact a Microscope Service Company. If you are in the Arkansas area that would be: Delta Optical Instruments, Inc. Email: robin@deltaoi.com
Oct 06, 2009 | Swift M2251C Monocular Microscope
Image rings when using Coolpix for microscopy
Under some circumstances when using the Coolpix 4500 attached to a microscope concentric rings are visible as in the below. The COOLPIX 4500 aspherical lens surface is ground to create the ideal curves to gather rays at the focal point with an extremely high accuracy. Such minute lines are not visible in the image taken with a camera alone, however if the camera is used with a microscope, the lines become visible as the depth of field is increased due to the combined F numbers of the camera lens and microscope lenses.
Aug 30, 2005 | Nikon Coolpix 4500 Digital Camera
Science & Laboratory Logo
271 people viewed this question
Top Science & Laboratory Experts
Pokinhas
Tom Chichester
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
