Refrigerators Logo
Tom Wiese Posted on Mar 12, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG FX28977ST the freezer only gets down to 32 degrees and the refrigerator only gets down to 43 degrees. It seemed to work fine until two days ago when it quit making ice and the ice cream got soft.
The fan works and I vacuumed off the coils but that didn't help
Paul
Level 2:
Sergeant:
  • Expert 381 Answers
  • Posted on Feb 04, 2019
Paul
Expert
Level 2:
Sergeant:
Answers
381
Questions
0
Helped
146110
Points
960
Call LG. Sounds like you have a sealed system issue. 18002430000
Mark Cheong
Level 3:
Master:
  • LG Master 791 Answers
  • Posted on Mar 12, 2018
Mark Cheong
LG Master
Level 3:
Master:
Answers
791
Questions
0
Helped
476177
Points
2475
First, I'm not a LG Technician. Call your LG vendor for service.
*** the following is for information only. ***
* Move food items to another refrigerator.
* Do a complete DEFROST of the box. (unplug it.) Expect it to take 4 or more hours. You must wait till all water stops dripping out of the fridge. Keep checking the lower defrost drip tray at bottom of fridge. Dump out water from tray as needed. DO NOT you a hair drier or any other heat source! The heat will warp the plastic. Use a small fan to gently blow into the freezer section.
* DO NOT use an ice pick or sharp object to remove ice! Just let everything melt. (The problem of ice is inside the coils)
* Plug in Fridge but don't put any food in. Set dial temperature to the Mid range setting. Set to freezer venting to normal. Set the refrigerator to mid range. Let it cool down to 0 - 10 degrees and start making ice (in ice maker) If it does not cool down to at least 10 degrees F then call for service. Suspect bad thermostat, Blocked condenser coils, Bad pump, etc. Qualified service tech required to repair.
* Cooling okay? Reload food but don't stuff it in. Leave space between the walls to allow cold air to flow around foods. It will take a day or so to cool down food properly. Note: I may take longer if this fridge is near a heat source like a Hot water heater, Oven, Range, Steam radiator, etc.
* If your still icing up in 2-3 weeks. Then check if the coils are icing up. Defrost is not working. This needs to be checked by a tech. Have him perform annual maintenance.
* Check door seals. Kids leaving the door open? High humidity? * Note how everyone uses the fridge; are they putting hot food in it? Open hot steaming food adds heat and humidity to fridge. Hot food with thaw out other frozen food and build up frost.
* Final, Have a Tech check your fridge. Have them perform maintenance and replace worn items as needed.
Aloha, ukeboy57
5 Related Answers
Anonymous
  • 152 Answers
  • Posted on Jan 21, 2008
SOURCE: Soft ice cream
there are vent openings in the back of the freezer you should not block that ..it will cause the temp to go up
Anonymous
  • 56 Answers
  • Posted on Mar 30, 2009
SOURCE: Food and water freezes but ice cream is soft
Check the door gasket seal.
Open the door for a few seconds and then close.
Immediately open the door again, and, if sealing properly, it should take more pulling force to open the door.
Anonymous
  • 76 Answers
  • Posted on Oct 26, 2009
SOURCE: Ice Cream In Freezer Is Soft
DON'T BY ICE CREAM! LOL Try putting ur ice cream somewere else
Anonymous
  • 43501 Answers
  • Posted on Dec 27, 2010
SOURCE: the refrigerator quit getting cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Anonymous
  • 43501 Answers
  • Posted on Apr 13, 2011
SOURCE: The freezer won't go under
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Amana fridge is not cold but freezer is working
If freezer is ok and cooling ( 5 degrees or less) one thing you might want to check is that the flow of cold air to refrigerator is not obstructed by the items in your freezer. The ductwork has to be available. Also check the opening of the damper if fridge is not cold enough. And is the fan operating at full speed - are the bearings dirty and slowing it down?
Also check your freezer temp - there are degrees of freezing. Water freezes at 32 degrees but a good freezer should go down to about zero. And the colder your freezer air is the colder your fridge will be.
Sometimes when the refrigerator temp is 37* some of the food will get frozen.
Your thermostat is faulty. The vegetables cannot freeze at 37 degrees. It will not freeze until it's at 32 degrees. The sensor is wrong as it is impossible to freeze anywhere above 32.
Top Bottom Amana worked fine until I cleaned the cooling coils. Now about every two weeks the fridge seems to go into an extended defrost cycle for about 14 hours during which it blows warm air into the...
Could be a number of things, low Freon, defective defrost timer. Suggest have a tech check it.
If it is 10 or more years old suggest replace it with a new one rather than invest funds in it.
I am trying to return the freezer and refrugerator settings to 37 and 0 , how do I do that?
There is a dial or button pad inside the fridge that controls the temperature up or down.
some displays are not so clear so just adjust your fridge slowly either way until you get to the desired temperature
37 degree Fahrenheit = 2.78 degree Celsius
0 degree Celsius = 32 degree Fahrenheit
2helpful
10 yr old, sits in a garage. Worked fine until a
is the fan operating,if so then check your damper vent door that throttles cold air from freezer to refrige compartment they can freeze shut and a hand held hair dryer will thaw them out,then adjust its control to make sure the door moves when control is adjusted
Top freezer quit freezing. Refrigerator works.
Good day,
Yes, the cold weather is the cause.
Your machine is cycled off and on by the thermostat located in the fresh food compartment. When the fresh food compartment is satisfied, it will shut off the entire machine.
Any temperature below 55 degrees will reduce running time until the freezer will not function, or at best poorly.
Engineers designed domestic refrigerators to balance properly between 70 and 95 degrees. It should be in your user manual.
Thank you for using FixYa
Amana refrigerator not cooling below 45 degrees.
the fan in the freezer section is called the evaporator fan. this fans main funciton is to blow cold air into the fresh food side. if its not running then you need to replace. make sure there is no frost build up on the rear wall in freezer section
1helpful
2answers
My fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Jun 17, 2009 • LG LFD25860
Freezer warnm up
It does sound like the normal defrost cycle. Aslong as it stays at an average below 12 degrees it is normally working fine. Check to make sure the back air vents and front grille are clean and the fan by the compressor is running when the unit is on. It has to get rid of the heat so it will freeze.
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
