Need to know weight trailer and truck proper leveling and which hitch
You will need to take the trailer to a CAT scale at a truck stop. The trailer should have a hitch, you just need to figure out what size receiver ball you need; 2" or 2-5/8". Each ball has a specific limit. That alone should give you an idea of the weight. At the CAT scale, there are several scale pads, put the axles on one scale and the tongue/jack stands on another. Your total will be from both scales but this will also give you an idea about the weight distribution.
Hi Frank,
I have a Durango 2000 and pull a 24 foot ski boot loaded with equipment. I don't know about you, but I wouldn't try towing anything without the trailer brakes connected. I purchased the Titan Trailer brakes setup and they've never failed me once. The hitch: just make sure you get the right towing capacity for your travel trailer. I have the 5.9 liter engine, which allows up to 6500 pounds of towing capacity. Your owners guide will explain how many based on engine size.
Good Luck, and happy traveling.
Mark
