Question about Amana Refrigerators
My freezer isn't cold enough. Are the higher numbers on the thermostat dial colder or are the low numbers colder? See full question below.
I have an old Amana refrigerator and the freezer isn't cold enough. It has a dial temperature control, numbered 1-7 (actually 7-1 left to right, with only the current number it's on showing). Which is the coldest - 7 or 1? I don't have the manual. The dial has an arrow on it pointing to the right, saying colder. Does that mean I turn the dial to the right for a higher number or that the numbers to the right, with 1 being the lowest in that direction, are colder?
  • 38 Answers
Higher is colder
Posted on Mar 02, 2018
6ya staff
SOURCE:
Anonymous
SOURCE: temperature adjustment
Answer the question is 1/2 or 4/5 colder?
Posted on Feb 04, 2007
Ronnie Houston
  • 2920 Answers
SOURCE: I have an Amana refrigerator
the higher the number the colder it gets
Posted on Jan 13, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Please confirm which is the
Hi.
Higher numbers are colder...
heatman101
Posted on Sep 11, 2010
oldTech2332
Gene Meier
  • 2341 Answers
SOURCE: in the cold controls for
the higher the number the colder it is 1 is warmest and 7 is colder
Posted on Jul 24, 2011
imufo2
Leo Ponder
  • 3773 Answers
SOURCE: we don't know if number
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 11, 2011
I have a Danby fridge with a numbered temperature dial. Does the higher the number mean a colder temperature? All my stuff keeps freezing
Keep your freezer to the mid point, and your ref to mid.
Wait 24hrs for results. If your refrigerator is still freezing, you may need a new thermostat. Get the model number, and go to searspartsdirect.com and look up the thermostat. Sometimes it's also referred as cold control.
Apr 18, 2016 | Danby Refrigerators
My freezer keeps already frozen food frozen but wont freeze fresh food
You need to put it at the top of the freezer in an upright freezer which is usually where the circulation fan is. With chest freezers you put them in the bottom. You may be able to make the freezer colder by turning the thermostat dial to a higher number. The higher the number the colder the compartment will be.
Get yourself a cheep fridge and freezer thermometer from Walmart. They have a green section where the red line should be. The freezer should be minus 18'C or 0'F.
http://i.walmartimages.com/i/p/00/07/23/97/00/0007239700696_300X300.jpg
Nov 03, 2015 | Freezers
Too cold
Refrigerators and freezers have a thermostat control inside the refrigerator compartment. It is normally some type of dial with numbers and a graphic indicating warmer or colder.
Place a thermometer inside the cold box. Wait one hour and record the temperature. Adjust the thermostat one or two numbers warmer, then wait 12 hours and record the temperature.
The interior temperature for a refrigerator must be below 40F for food safety. A good range is 35-38F.
Jul 26, 2012 | KitchenAid KBFS25EVMS Stainless Steel...
Is the dial to adjust temp coldest set at low numbers or high number?
The dial inside the fresh food compartment, the bottom compartment
set to middle or above (higher numbers mean colder). Usually 5 to 9 if it has numbers.
Freezer knob in the middle if it has one. (If you set a freezer knob to "colder" it cuts
off the cold air to the lower compartment). Hope this helps
Jun 29, 2011 | Kenmore Top Freezer Refrigerator
Kitchen Aid Unit - maybe 4-5 years old but past warranty. Freezer not freezing. Not that cold in fridge. I played with the dials 1. Are higher or lower numbers on the knob coldest? 2. What else should I...
Set dial to higher number in the fresh food compartment (large door) set the freezer
knob on the vent stack in the center or to the left (if it is set to colder, this prevents cold
air from getting into the lower fresh food compartment). Colder means the freezer
gets colder.
Also if you have a failed defrost termination thermostat it will cause this
symptom on many models. (a lot of folks will disagree but I have only seen a couple
of defrost timers fail in 10 years). The water makes its way into the defrost termination
thermostat and corrodes the contacts inside. It is behind the freezer panel and has two
wires going to it. It is clipped onto a tube. You will need the model and serial from inside
the fresh food door (on the side panel) to get a new one, usually less than 20 dollars.
Remember to set the fresh food compartment temp from 34 to 39 degrees with a
thermometer in a cup of water for 24 hours. Don't forget to unplug unit if service is
required on the thermostat. Hope this helps.
Jun 08, 2011 | KitchenAid Refrigerators
My GE TFX30PP is constantly running and doesn't turn off. The freezer is very cold but the frig side isn't cold enough. A repair guy put in a new "cold contol" sensor but it didn't help.
This is a very common issue, If the freezer compartment is cold and making ice the
problem is simply airflow from the freezer into the refrigerated section.
Typically when one senses the refrigerator is warm they max out the settings
on both dials the thermostat with its 1-10 settings as well as off for the compressor.
This controls the compressor and temperature.
The additional setting or dial is for colder freezer or refrigerator as well , However
it simply opens or closes a flapper door between the freezer and refrigerator boxes.
When that dial or setting is maxed , it closes and makes the freezer colder, yet leaves the refrigerated section starved for sufficient airflow to maintain a cold box in the refrigerated section.
Just set the dial that does not turn the compressor off to the middle setting.
One can leave the thermostat that does control the compressor in the max setting , just not the colder freezer setting, If you notice colder isnt colder refrigerator, Its actually colder freezer, A common issue found on 25% of all refrigerator calls a simple setting adjustment.
Its easy to think that maxing out the settings makes for a colder refrigerator, it doesnt, it makes a colder freezer and warm rerigeration section.
If a freezer is making ice, theres nothing wrong with the unit other than airflow setting.
I would also clesan the condenser coils off.
Add a comment
Dec 24, 2010 | GE Profile Performance 29.8 cu. ft....
What is the best temperature for the bottom freezer and refrig?
Set both dials in the middle.
If you have a nearly full freezer, add 1 dial unit.
If you have a nearly full refrigerator, add 1 dial unit.
If your freezer is less than half full, step down 1 dial unit
Refrigerator should not be less than mid-point on dial (it gets open more often).
This is a good starting point, adjust in a month or so.
Sep 21, 2009 | GE Monogram ZICS360NRRH C... Bottom...
Freezer is not cold enough.
Turning it to the right will make it colder. It will only regulate the temp. by few degrees, so if your thinking there will be a big change there won't be.
Jul 31, 2009 | Viking Freezers
Temperature control
I have a danby mini fridge and freezer and noticed the same problem. The temperature dial has NO NUMBERS ON IT! it just has a strip that goes from light to dark blue. That's it. I looked in the manual and it doesn't say anywhere which way is colder...it makes sense that the darker the blue the colder the temperature but why keep us guessing?
Mar 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Refrigerators Logo
271 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
