SOURCE: I WOULD LIKE TO RETRIEVE
There is software you can buy to do this task
http://www.datadoctor.in/data-recovery-software/sim-card-data-recovery-software.html
This link provides you with a software and explains what it does and compatibility. You will need a USB cable to hook up the phone to the computer.
http://www.driverecovery.in/drive-recovery/sim-card-data-recovery.asp
This software is $69
The information is on the SIM card in the phone. (internal phone memory card)
You can also google in "Recover Deleted text messages"
There is alot of software out there.
Good Luck
SOURCE: vb 6.0 ado connection without ado control moving next record
I see 2 problems with your code.
1) Each time you call cmdnext_Click, you're reopening the database. Each time you do that, you start at the beginning of the file. You need to have the database opened once, somewhere else in your program. Be sure that the record set is visible from this sub.
2) In order to use the "Next" function, you need a loop like this
'test for no records
IF REC.BOF and REC.EOF then
msgbox "No Records Found"
exit sub
end if
IF NOT REC.EOF then
REC.MoveNext
(display your fields)
END IF
Again, this will only work if your database is opened outside of the cmdNext_Click routine.
SOURCE: My Nokia N73 cant recieve text messages, it can send but cant receive.... :(
you need to format your phone so that you can receive messages again...input this code *#7370# and then click yes...enter your security code...after that your phone will reboot...it will automatically on..so please wait until the phone open..after that enjoy texting again..hope this will help you
SOURCE: cant recieve text messages on lg neon
i hate my lg neon sooo much its been 2 months and it doesnt work and it fell apart and i havnt told anyone i had to snap it to gether but it is so fragille and wobballly
SOURCE: my SMS messages don't show when i recieved them, just the date!
there is a sprint sms timestamp patch that you can download on to your phone that'll show the time of an incoming message. It works fine on my treo pro.
http://www.wmexperts.com/treo-pro-cdma-gets-official-2016-sms-time-stamp-patch
