It is a water inlet malfunction, is the flow valve to the pipe turned off or is there a coil/loop or a bent part of the water pipe that fills it? Or is the pipe to long which causes movement when filling which alters the water rate that upsets the sensor?
It will be one of these options which will quickly resolve the issue, I do hope this helps.....
SOURCE: Dishwasher - Kenmore 461 14352 - E2 error?
With registration, you can probably get a download of your manual (user guide) here:
http://www.managemyhome.com/mmh/
It may not contain the info you need since appliance service people hate do-it-yourselfers and, in my mind, manufacturers collude with them.
Can you believe that many TVs, radios, PC monitors etc. once came with complete circuit diagrams?
SOURCE: E2 error code
In reading the manual for this coffee pot, it needs to have the descaling procedure run. The manual lists running a mixture of 6 cups water and 6 cups vinegar in a normal brew cycle...twice to clean hard water deposits from the machine. It says to make sure to remove the filter basket. Once the procedure is complete, unplug the unit and replug in to remove the E2 code.
SOURCE: E2 error in smeg dishwasher
e2 is overfill or flooded base.
take the bottom front panel off and see if there is water in it and if so, mop it out. if it reoccurs, then you have a leak.
you will see a float device in the front approx middle and this is what actuates e2. if fault is intermittant, try putting a small weight on this - a washer for example.
if e2 is being caused by overfill and not a flooded base, then the water intake moulding needs replacing
SOURCE: error code E2
Error Code E2 means the pump is blocked. The remedy is to take the filter out which is underneath the bottom dish basket and ensure its is clean and free from debris. Then use a small container to empty the water sitting in the bottom of the machine/filter housing and ensure that no waste is stuck in the bottom. That should clear it
SOURCE: water leaking from bottom of
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Hey friend, thank you for your inquiry!
The "E2" error code means that thermistor/turbidity sensor has failed. This can be corrected by replacing the turbidity sensor or main control board. I would suggest contacting a professional to come and properly diagnose your appliance to avoid any unnecessary part purchases. -Matt
