I am terrible with all the technical end of pgotography. I shoot with Nikon D800 and prefer using Aperture priority mode
SOURCE: aperture priority only in manual mode?
Yes. You pick the apature (the 3000 keeps it aorund the setting you pick) and then it automaticly adjusts the speed for you.
SOURCE: Blue tint when shooting aperture priority
Hello, First of all let's explain what aperture priority does in terms of electronics and mechanical/optical changes in the way the camera takes photos. Unlike most point and shot digital cameras, your one has variable aperture range. Aperture is related to your camera lens. Their main function will be to collect light and direct it to the camera's sensor. The aperture of a lens is the diameter of the lens opening and is usually controlled by an iris.The larger the diameter of the aperture, the more light reaches the image sensor. Aperture is expressed as "F-stop", for example F2.8 or f/2.8. The smaller the F-stop number (or f/value) the larger the lens opening (aperture). This means that when you're using aperture priority or large aperture values (a smaller f/value) your image sensor (ccd or cmos) will tend to receive more light or slightly overexpose itself. Most simple digital cameras, the point and shot ones, have a fixed aperture, the lens are fixed and that's set to a so believed "optimum" range in order to produce best pictures when using automatic settings. SLR or semi SLR digital camera's woun't achieve best performances when using them on automatic settings, they aren't designed in the same way as the simple camera's. These camera's will tend to either overexpose, or have lighting/colour problems or achieve blurry images when using automatic settings. Any SLR or semi SLR camera user will be required to understand the way photography (electronic photography) works in order to achieve the best performances with it's camera. For your example, I guess the shots have a blue tint on them when you're using natural sun light in your photos, or in room pictures are illuminated by natural sun light. This is the first sign of overexpure, and the best way to reduce it and it's efects is to manually set the aperture range. Note that higher values will reduce the light that passes to the sensor, so you will want to experiment a little with those in order to achieve the best performance. When you take photos in light environments, bright sunny days or in rooms that contain many white surfaces or walls (these reflect the light pretty much and can overexpose the camera even if it doesn't look that bright when you look at them with your own eyes) you may want to use larger aperture value in order to have little light come to the sensor. Look for the highest values in aperture (in your menu) for example F8 or F16. If the pictures come out to dark or miss some details, you may want to use larger apertures (smaller numbers). Try these tests in order to check if your camera's problem can be solved this way. If not please reply back and we will look on the hardware - firmware side of the problem. Regarding aperture a quick recap :) A large aperture allows more light to reach the sensor. It's good when taking portret pictures and also achieves that nice blurry background surrounding your main subject in the picture. It's defined by smaller numbers (for example F1.8 or F1.2 or smaller). A small aperture allows little light to reach the sensor. It's good to take pictures in bright sun light. It's defined by larger numers (for example F16 or F22 or larger). Hope this helps, Bogdan.
SOURCE: Sigma 170-500mm APO lens on Nikon D50 won't autofocus or shoot
When you get a flashing EE, it means there is an Eror somewhere. Most cameras have a botton you press to reset it. Usually it is the battery check button. Try that. Also try taking the lens off the camera, unlocking the aperture ring, remount the lens and then lock the aprture ring to the minimum F stop. I think this should solve the problem.
SOURCE: Aperture priority not working...HELP!!
Hey Mike, This is an easy one. With the battery grip attached, you can only have either Shutter Priority or Aperture Priority work properly. You can change it with the custom function settings of the camera. So you can change it to work with Aperture Priority if you use that more so then shutter priority won't work. Brandon
SOURCE: slr e 500 can you advise on the best technique to
First of all this is a big subject that you cannot learn from just a few lines of infomation. If you are interested to work professionally ,then it is better to attend a full time or part time course in professional photography that is run by various institutions. You will need practical coaching , guidance and taught fundementally the subject. Once you under the technics of the cameras-- digital or celluloid- the variation of the shutter speed, the aperture settings , the angles of focus, lighting , all this needs a certain degree of combination that makes you a professional photographer.
check and join online :
http://www.betterphoto.com/online-photography-courses-2-b.asp
Also check the following link:
http://www.schoolofphotography.com/
Please comment
