SOURCE: UL Code
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust? The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles. Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around. Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load. That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
SOURCE: My whirlpool cabrio washer will not stay balanced
the repair man says i need to replace the inner tub for 299 dollars with a total price of 424 and its only 4 years old
SOURCE: F50 error code and Whirlpool Cabrio
JUST SPOKE WITH WHIRLPOOL ABOUT THE F-50 CODE. THEY SAID THAT THEY ARE AWARE OF THE PROBLEM AND THEY ARE PAYING TO FIX IT. ALSO THE CONTROLL BOARD AND THE RPS SENSOR MUST BE REPLACED TO FIX THE PROBLEM. THE OWNER MUST CALL WHIRLPOOL, NOT THE TECH, TO GET THEM TO PAY FOR IT. HOPE THIS HELPS.
SOURCE: whirlpool cabrio loud noise during spin cycle
The inner bearing will be faulty kindly replace the inner bearings as well as water seal before that kindly check whether the drum is freely moving with out any shaking If you find any shaking means you are suppose to change the drum only
SOURCE: My Whirlpool keeps flashing and
UL means the load is unbalance. Open the lid and rearrange the clothes. If the problem continues, then the machine may have a problem caused by rust. If the unit still under warranty, contact the manufacturer for assistance on repairs.
If the appliance is out of warranty and you are a handyman (That works with safety), you may try a repair as indicated by a FixYa Tech:
"open
try another load."
Source: Tellmer
