Watches Logo
B
Bill Jacobs Posted on Feb 25, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to set a model 40/8309 to standard time and not have it jump to military time?
Terry
Level 3:
  • Watches Master 11,377 Answers
  • Posted on Feb 25, 2018
Terry
Watches Master
Level 3:
Answers
11377
Questions
Helped
4625388
Points
152765
Try this and report back whether it works for you or not:
Press the MODE button (B) three times to enter the time setting mode. Press the RESET button (A) to tab through seconds, minutes, hour. The ST/STP button (C) scrolls through the number choices. When selecting the hour, if you want 12hr time format make sure the AM or PM is displayed next to the number you desir. There are 48 possible selections for the hour - 12 for AM, 12 for PM, and 24 for military time. Keep cycling through until the correct hour comes around. Once you have the correct choice, press the MODE button once more to exit time setting mode.
http://fitness.manualsonline.com/support/armitron/watch/i-cannot-get-my-watch-off-military-time-5752670
5 Related Answers
Barbara Phillips
  • 29 Answers
  • Posted on Mar 08, 2008
SOURCE: Convert Military Time Setting to Standard
If its the watch I think it is try holding in the top right button on the watch. That should change it back to 12 hour time
Anonymous
  • Posted on Nov 12, 2008
SOURCE: kenneth cole reaction
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Anonymous
  • Posted on Feb 26, 2009
SOURCE: Timex Mid Size Sports 1440 WR50M
If your set up is: Top-Left=Indiglo Top-Right=St./Stop Bottom-Left=Mode Bottom-Right=Lap/Reset
Than follow these steps:
1. Press Lap/Reset and hold. You should see the time the alarm was set for.
2. While holding Lap/Reset, press Mode.
3. Let go of all buttons.
4. There you go!
Hope that was a help
Anonymous
  • 4 Answers
  • Posted on Apr 26, 2009
SOURCE: Can't get kids gap watch move from military "24" hr time!
hit mode three times until TUES flashes and the seconds. Hit reset until the hours flash and hit start to change them. The watch goes from AM hours to PM and then back through AM and when it cycles through the PMs for the second time, they will alternate 12/24 hour time.
Anonymous
  • Posted on Jul 31, 2009
SOURCE: Set watch
I have a G Shock DW-004 made in 1997. I had this same problem, and I tried everything to change TO military time and back to standard time. I just read the bit to try and was about to do it. I pressed the top left button to get the time to flash, and hit the light button by accident (the one with the big G on it) and VIOLA! It changed to military time. So in my model, anyway, the G light button (under the display on the edge of the watch body) changed the time to military from standard and back again, when the time is flashing.
Get marathon CL030062 off of military time
To convert a marathon CL030062 (military time) to standard time, simply subtract 1200 from the time and add "AM" to the result. For example, CL030062 in military time is 3:00 AM, so in standard time it would be 3:00 AM.
1helpful
I have a G shock 1659 model, kinda old, but I don't know how to get it off military time, how do i change it to standard?
go into your menu setting and after the time set it should allow you to choose between 12hr and 24 hr modes
13helpful
Change military time on aw205
When in the time set mode press the A button, this will toggle from military time to standard. I discovered this through trial and error, not in instructions.
1helpful
I have a Athletic works watch and I can't get it off military time.
When in the set time mode press the A button this will toggle between standard and military time. I had the same problem, dscovered it by trial and error, not in instructions.
13helpful
4answers
Athletic Works Watch
With time displayed:
Press lower right, then upper left.
2answers
Roxy 80' W056DR
Possibly, you could push the hour-setting button through either the military or standard time setting, i.e., there are actually 48 "hours" you can set your watch to and you need to cycle through enough of them to reach the standard or military hour you want.
26helpful
5answers
4. There you go!
8helpful
2answers
Mar 07, 2008 • Watches
6helpful
3answers
Set watch
Feb 21, 2008 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
