Please register it on the manufacturer Hisense web site, and review the help there.
https://www.hisense-usa.com/support/models/65h7b2
What exactly are the problems that you are having with the volume on this TV?
SOURCE: netflix problems
maybe this can help. If not, please supply your TV model.
You need to register with Netflix online first to create a login and password.
Here`s how to:
>> On your computer go to netflix.com then click signup or signup.netflix.com
>> Fill all the necessary information they needed.
>> Purchase any plan they offer after you created an account(Optional as you can avail a trial version for 7 days)
Now go to your TV
>> Turn the TV on then hit menu
>> Go to My apps menu
>> Select Netflix
>> Sign in with your username and password
>> Take note of the code
>> Go to your computer and login to netflix.com/activate and type in the code to activate.
>> Go back to the TV select finish to start the service
Important:
Make sure your TV is connected to the internet, either wired or wireless
Here are the three methods to connect wireless on your TV:
Scan and connect
>> Turn on the TV
>> Go to Menu
>> Go to Network settings
>> Select easy then scan for networks
>> Select and connect
Connect using WPS
Press the WPS button(Padlock with signal wave) on your TV`s side panel then on your router.
Note:
You only have two minutes before the router turn the WPS off
Add network manually
>> Go to Menu
>> Select manually add network
Type and select the appropriate settings:
SSID: Name or the Wireless network
Security: Either the WEP, WPA, WPA2 or WPA+WPA2
Passphrase/Passkey: Type in the password
Wait for a prompt that the TV is connected to the internet.
SOURCE: What's the difference between a hisense smart TVs and a hisense smart led tv
LED Smart TV saves Power and Contrast & Colour you will get better than Smart TV.
SOURCE: How to program the netgear smart TV remote to a hisense 42' flat screen tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
It appears you have a problem in the power supply section of the set and it shuts down to prevent any damage. Check the PS board for burnt resistors or bulging capacitors.
Bill, The 50H7GB's smart features are based on the Opera OS. Hisense uses an Opera-based platform for its connected features the same system/browser you'll find on Nintendo's DS and Wii video game systems.Check the attached links,instruction and guides, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Hisense H7GB2 4K Ultra HD Smart TV Review 50H7GB2 55H7B2 65H7B2
Hisense 50H7GB
Hisense The H7 4K Ultra HD TV
