Televison & Video Logo
Mich Duque Posted on Feb 24, 2018
JBL HARMONY IN THE SCREEN SAY SUBCLOCK AND DON'T ON (I have this issue) It has been in storage for over a year and I'm assuming it's battery?
1helpful
My logitech harmony 1000 doesn't work after charging overnight. I have to hook it to the computer to update it. Is this a battery issue?
When was the last time u replaced the litium battery?If 2 years or more the litium battery has not been change.Yes,it is the litium battery issue.
7helpful
2answers
Blank screen but backlite is on
Had the same exact problem. Blue screen, no text, but remote worked ok - if you could figure out which buttons did what. Tried every solution posted online - battery pull for 10 sec, battery pull for 1 hr, and battery pull overnight. Tried updating software, firmware, but nothing worked. Found a replacement screen on ebay for $26 shipped, replaced it in less than 5 minutes, and works great.
1helpful
LCD doesn't display anything. Removed battery and reinstalled. No success. Is there a reset process?
try these steps to fix the problem your experiencing with your LCD. most of the time this will work.
1- Remove the battery from the Harmony Remote for 10 seconds and insert it back in, and test the remote to see if the screen is displayed properly. If this does not fix the issue, please proceed with the following steps.
2- Make sure you have the latest Logitech Harmony Software (version 7.6.0) installed on your computer.
3- Connect your Harmony Remote to the computer. Run the Logitech Harmony Remote software on the computer and Login to your account.
4- Click on the "Downloads" button at the top and select "Firmware"
5- Remote will go through the firmware update, which will put the Harmony Remote back to Factory Default with the most updated firmware. Then software will ask you to select "Yes" to update the remote and click on "Next" to do a remote update, which will take the information on your account with your Devices and Activities and bring them into the Harmony Remote.
6- If this Firmware Update process does not fix the LCD screen issue, try doing a Firmware Update in "Safe Mode". To do this; remove the battery from the remote, press and hold the "Off" button on the top of the Harmony Remote and insert the battery back in to the Harmony Remote. Screen will display "Safe Mode" and then please follow the steps 3 through 5 again.
1helpful
NO LCD DISPLAY
I have the same problem
Hey!
I had this same issue with my Harmony Remote. Logitech sent be these steps and they got it working right!!!
1) Remove the battery from the Harmony Remote for 10 seconds and reinsert it. If this does not resolve the issue, please continue troubleshooting.
2) Ensure you have the latest version of the Harmony Remote Software (7.7).
3) Update the firmware on the Harmony Remote. The following link shows how to complete this task:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=10747
4) Try putting the Harmony Remote in safe mode and complete the firmware update again. The following are the steps to accomplish this:
a) Remove the battery from the Harmony Remote.
b) Press and hold the power button while reinserting the battery into the Harmony Remote.
c) To get out of safe mode, remove the battery for 10 seconds and reinsert it into the Harmony Remote.
I hope this gets the display on your Harmony Remote working too!!!
-Kennedy
Harmony
Top JBL Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a JBL Televison and Video Expert? Answer questions, earn points and help others
