Question about Yamaha Audio Players & Recorders
Yamaha RX-V663 AMP will not communicate with remote. How to fix it
    Loyalty:
    Visited the website for 30 consecutive days.
  • 130 Answers
(1)download yamaha rxv663 service manual.
(2)read p.152-154
(3)make sure your remote matches with remote ID.
how to check remote IR diode
(1)switch on mobile phone camera
(2)point it to remote IR diode.
(3)Do not take any photo & press any remote buttons.
(4)White light flash.
how to check IR receiver
(1)locate the front panel.
(2)find out IR receiver.
(3)find an analog multimeter with 0.5V selected.
(4)black probe to ground, while red one to IR pin.
(5)press any remote button.
(7)deflection occurs
Posted on Nov 03, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Audio but no video from Sony Blu-Ray w/ HDMI hookup to RX-V663
Okay...my first contribution to any forum but I have the same problem (Yamaha RX-V663 and Samsung Blu Ray) and found the solution. The problem is you probably have your HDMI cables from your DVD player and reciever connected to a DVI input on your TV. The DVI may have problems communicating--not HDCP compliant. My system was working great then I hit a button on my remote...just playing around. I think it was the pure audio and I turned off the receiver. After that, the audio worked but there was no video. After many frustrating hours, the fix was to unplug the HDMI and DVI cable then turn the power off, cycle the power again, and plug the HDMI and DVI cables back in (the DVI was the last cable plugged in, not sure if that matters). By unplugging everthing you've reset the communication between the HDMI components and the DVI TV.
See page 18 of the yamaha owners manual, second to last note on bottom right of the page. It says there may be a problem...
I also noticed that the yamaha reciever was sending 1080p (my older tv is 1080I) and that is why the video wouldn't display on the TV. You can see this in the video signal info screen, unfortunately there is no setting to switch it back, just recycle the cables and power and it should reset.
Uncredibly frustrating but I got my picture back!
Jason
Posted on Jan 10, 2009
Anonymous
SOURCE: Need Scientific Atlanta code for Yamaha Rx-V663 remote
043, 011, 003, 041,042,045, and 046
Posted on Jan 24, 2009
Anonymous
  • 144 Answers
SOURCE: on zone 2 of my yamaha rx v663 receiver it says fixed when I try to adjust the vlume and won't let me cut it up or down.
Check the setup menu of the receiver on zone 2 settings most likely the error is a fixed volume setting for this zone. If not found, reset factory settings and try to setup everything again. If the problems persists, contact your vendor if still under warranty.
Posted on Apr 17, 2009
bernardlunda
bernard lunda
  • 318 Answers
SOURCE: can i use panasonic SB-AK57 speaker (6 ohm) with
yes only that the current will be less on the load.
no problem you can use .
also consider the watts of the speaker and the amplifier dont forget. the speaker should have more watts rated than amplifier output watts
Posted on Apr 25, 2009
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: Yamaha receiver RX-V663
Make sure you have an analog RCA audio cable from the source to the receiver. Digital coaxial or optical will not work for zone 2 or zone 3. By adding an analog cable it will not affect your main zone, it will always go to digital first. Hope this helps
Posted on Dec 29, 2009
Testimonial: "great feedback. "
Yamaha RX-V663 Amp will not communicate with remote
You have this backwards. The remote control is the source of the codes that apply to your Yamaha amplifier.
Feb 18, 2018 | Yamaha Audio Players & Recorders
Yamaha RV-X663 not powering up.....
it is probably in protect mode. Try holding the 'straight' and 'audio select' buttons and pressing power. See what happens.
Nov 14, 2014 | Yamaha RX-V663 Receiver
I would like to control my Yamaha RX V563 amplifier with my dish remote control.
You should be able to find remote codes and instructions for programing them on the dish network or direct tv websites
Apr 18, 2010 | Yamaha RX-V663 Receiver
Yamaha rx v663 receiver, turntable input
What you will need is a phono pre-amp, then you can run into the receiver with a line level input to an empty audio input on the receiver, you can try Radio Shack to obtain one.
Feb 10, 2009 | Yamaha RX-V463 Receiver
Yamaha RX-V663 delays 10-30 seconds between commands using the remote control. New batteries, new receive. For example, try to raise volume. It goes up 1 dB then cannot give any other commands using the...
I have seen this type of thing with several remotes.  You have some light source in the room that is interfering with the reception of the ir.  Turn off all light sources in the room and then try.  You might be surprised!
Dec 20, 2008 | Yamaha RX-V663 Receiver
Jason
Dec 01, 2008 | Yamaha RX-V663 Receiver
207 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
