Question about Food Processors
Finding replacement parts for rival food slicer model 1101/8
  1. replacement part
  2. rival food slicer
  • 23 more comments
  • Anonymous Dec 05, 2007
    NEED THE STEEL SLICING
  • Anonymous Feb 24, 2008
    Need a replacement slicing blade
  • Anonymous Feb 27, 2008
    need replacement blade for rival food slicer model 1030
  • Jeff Chism
    Jeff Chism Apr 04, 2008
    Looking for a repalcement Blade. Abtecparts.com no longer has repalcement blade available.
  • Anonymous Apr 21, 2008
    need replacment blade for 1101
    The plastic disk on the slicing blade has broken and I need a new plastic disk. The metal part of the slicing blade is fine.
  • Anonymous May 28, 2008
    need new blade, the plastic teeth keep breaking
    can't find anywhere and abtecparts.com site gives error site not found
  • Anonymous Sep 01, 2008
    Need a new plastic piece that holds the meat down while slicing for a model 1038
  • Anonymous Oct 02, 2008
    Has anyone found a place to buy a replacement blade for the 1101?
    The plastic gears on mine broke.
  • Anonymous Oct 14, 2008
    Plastic gear binds, blade is fine but is it true that no replacement is availbale?
  • hackerrealty Oct 31, 2008
    im looking for a part on the rival electric slicer 1101E/6. its a small wheel that turns the blade, The teeth are broken
  • draperpam Dec 11, 2008
    I need the little plastic nut that holds the blade on - can anyone tell me where to find it?
  • Anonymous Dec 15, 2008
    I'm looking for a replacement blade for rival food slicer model 1101E, 63/8 inch blade. My gear broke and now this blade is useless. Thanks if you can help find a replacement blade.
  • Anonymous Dec 26, 2008
    Plastic gear ring on back of blade just broke, otherwise good (would consider selling rest of unit for parts if another blade is not available)
  • mendobakery
    mendobakery Jan 07, 2009
    Stripped threads on gear on back side of blade.
  • Anonymous Jan 25, 2009
    I have two of them here at home......it's a dam shame that the plastic gears are all that wrong with it
  • rbmccall Jan 30, 2009
    I as well have the Rival food slicer and in need of blade for model 1101/8, otherwise unit is as good as new
  • mitchster1o1 Mar 19, 2009
    i need a blade fer model 1030 foodslicer
  • Anonymous Mar 26, 2009
    I am looking for a replacement motor and blade for a rival slicer, model No. 1101E-04
  • Anonymous Apr 06, 2009
    I need a replacement blade for my Rival 1101/3. On one of the websites mentioned above it says no longer available. Does anyone know where I may get that blade. Mine works great other then that.
  • Kathy Jun 23, 2013
    I need the idler gear for a Rival slicer model #1101#/3
    Need an idler gear for my Rival slicer Model # 1101E/3
  • Larry Allin Sep 05, 2013
    I recycle parts for models 1005 thru 1030 and 1101; I also have some newly manufactured, functional replacement parts for those models. To inquire about availability of what you seek mailto:lallin@juno.com
  • Geneva Grosstick
    Geneva Grosstick Dec 29, 2013
    Where can I find the feet for my Rival meat slicer?Mop 1101E/4
  • Michelle Marchese
    Michelle Marchese Dec 27, 2016
    Looking for the Retainer piece for model #1030V
    New Friend:
Take a look on amazon here Amazon com rival food slicer parts I hope I have helped. enjoy
Posted on Nov 22, 2014
I have a rival food slicer model number 1101/8. The gears on the blade broke. I need a whole new blade where can I get one.
Posted on Nov 25, 2008
Abtecparts.com/rivalslicers.htm
Posted on Nov 27, 2007
    New Friend:
  • 26 Answers
I am parting out a Rival 1101E (no sub-model number). I have a good blade 6 7/16" diameter. Fine as is; even better if sharpened, which can be done by most knife sharpening services.
I also have a used motor for this slicer; it powers up and runs fine, but has not been stressed tested.
I also have new suction cups to replace the rubber feet on all Rival slicer models. These are different than what came on the slicers orginally; but, fit well and work even better. I have many happy users of these suction cup feet.
finding replacement parts for rival food slicer mo - 2_7_2013_7_05_46_pm.jpg
Posted on Nov 23, 2009
  • 12 more comments
  • Larry Allin Nov 23, 2009
    email lallin@juno.com
  • Larry Allin Nov 29, 2009
    Can anyone describe the washer behind the blade that many slicers seem to be missing? If I know the size (thickness, inside and outside diameters) and material (felt, brass or???), I can very likely find a third-party source for replacements. According to my manual, the part is the same for 1101 and 1030 models, therefor, measurements from either model will do.
  • Larry Allin Jan 16, 2010
    Blade and motor mentioned in Solution #4 are no longer available.
    An idler gear, food tray, spur-clamp/food-pusher, blade-retainer & thumb screw set, and replacement rubber suction cup feet are available. email lallin@juno.com for more information.
    Food trays differ on the various sub-models; let me know the complete model designation (1101E, 1101E/1, 1101E/4, 1101E/5, 1101/4, 1101/8 use one style, 1101, 1101E/6 and 1101E/7 a different). It would be best to describe the slide rails and mounting method (springy clamp on or between rails and attached with clip) your slicer uses.
  • Larry Allin Apr 13, 2010
    Idler gear and blade-retainer/thumbscrew set mentioned earlier are no longer available.
    New rubber suction cup feet (set of 4) continue to be available; many happy buyers of these cups.
  • Larry Allin Aug 13, 2010
    Regarding solution #6 and parts I have available: the only remaining parts I have are:
    - thickness regulator for 1101 models
    - sets of 4 NEW rubber suction cup feet that fit all of the metal Rival slicers (many other brands too); but not the folding plastic models.
  • Larry Allin Jan 30, 2011
    A food tray and a thickness adjuster remain from my used/recycled parts offering.
    New, rubber suction cup feet continue to be available in sets of four. I sell 50-70 sets per year so my stock is always fresh, with supple rubber.
  • kudmebud Apr 27, 2011
    how much for 4 suction feet to 53821, wisconsin. thnx chris
  • Larry Allin Apr 28, 2011
    Inquiries about availability and prices: lallin at juno dot com
  • Larry Allin Jul 07, 2011
    All of the recycled parts mentioned in my comment from a year ago are gone.
    New, functional replacment parts are available as follows:
    Newly manufactured rubber suction cup feet, sold in sets of 4; nearly 200 sets have been sold to very happy customers.
    Replacements for the thumb nut used to secure the blade; look different but work well.
  • Larry Allin Sep 01, 2011
    I am once again parting out a Rival slicer and have some desirable part to offer. As of 9/1/11 the following parts from a 1101E/3 are available:
    -6.5" blade
    -idler gear
    -washer
    -motor screw
    -motor; runs strong - plastic and chrome housing
    -food grip, aka spur clamp, aka food pusher
    -thickness regulator
    New, function replacements continue to be available as follow:
    - suction cup feet, in sets of four
    - thumb nut to secure blade; sorry, no blade stud, just a nut.
    lallin@juno.com
  • Larry Allin Jan 11, 2012
    I now have washers suitable for use between the blade and blade backing panel. They are not original parts; rather they are functional equivalents. Also, now have functional equivalent blade retainer nuts (not the square shaft bolt), For information on these items, replacement suction cup feet (hundreds of very happy customers) or availability of used parts, please contact me at lalin@juno.com. mailto:lallin@juno.com
  • Larry Allin Jun 14, 2012
    In addition to the new suction cup feet I offer for most Rival 1101, 1005, 1010, 1015, 1020, 1025 and 1030 slicers, I also now offer blade washers. These are friction-reducing Mylar washers that mount between blade and blade head (backing plate) and are functional replacements for Rival part number 854-023. Mailto:lallin@juno.com for more info.
  • Larry Allin Aug 05, 2013
    New this week, threaded shaft for Rival slicers 1005,1010, 1025, 1030, 1101; $25 postpaid to US and Canada. Act fast, these sell quickly.
I believe I saw your desired part at www.abtecparts.com/Rival_slicer_1101.htm. I was looking for the washer behind the blade. I found a listing there, but the washer was marked no longer available. Not the case with other parts.
Posted on Dec 09, 2008
    New Friend:
I contacted Rival via email because I too need the bolt that attaches the blade to the unit, model 1101E/7. Rival responded saying this part is not available. Furthermore they could not even give me the dimensions. They did offer a 25% discount on a new slicer, but Ebay has better deals. I would take the slicer to a local auto parts store and find a bolt that works, but that might not be safe.
Posted on Feb 25, 2010
    New Friend:
I need a blade for a rival electric food slicer mod # 1030/7. Can't find one anywhere. Might just go buy a new slicer.
Posted on Dec 02, 2009
I have a Rival meat slicer, model 1101-E - Like new, never used, with original book - I'm selling it for $25. 352 422 6946 - Scott Noffsinger at Scott Noffsinger.com - Will be going to ebay auction soon!
Posted on May 17, 2009
JATA Model CF1007, 230 V 90W Food Slicer. Type TSK-962
I require to replace the plastic gear that connects the motor spiral drive shaft, to the cutting blade gear.
The gear side that connects with the motor drive shaft is approx 42 mm diameter with 40 gears, width of this gear is 6mm, the length of the double gear is 32 - 33 mm, and the gear on the other end is 20mm diameter with 20 gears, width of the gear is 8mm.
Posted on Apr 03, 2012
  • 3 Answers
Motor will not run, need bushers
Posted on Nov 29, 2008
    Problem Solver:
I was wanting to know if any one know where I can get a the tray the meat sits one?
Posted on Aug 08, 2009
I also have the problem of needing a part. My 1101/6 has a broken idler gear. Other than that, everything is intact. I will sell the entire unit for spare parts to someone for $25 and $ 5 to ship in the USA.
E-mail me if interested at gdb.lake@yahoo.com
Posted on Feb 16, 2009
    New Friend:
If you need suction cups just put a rubber mat under it
Posted on Mar 24, 2015
Anyone have suction cups for the rival food slicer?
Posted on Apr 05, 2012
  • Larry Allin Apr 05, 2012
    If you are referring to the four rubber suction cup feet, not the single big one, then, yes. I offer a functional replacement. The cups I offer are black, not gray; but, otherwise are a direct replacement for the the screw-in rubber feet on many models of Rival slicers, grinders, choppers, etc. Email for more information; lallin@juno.com
    New Friend:
Please send me a phone number so i can order a blade for my meat slicer model#1101/8
Posted on Mar 06, 2011
    Problem Solver:
Check EBay. Parts are listed all the time
Posted on Dec 17, 2010
  • Bob Gillette Dec 17, 2010
    Rival meat slicer parts are on EBay all the time
    New Friend:
  • 5 Answers
I have the blade and whole unit minus the suction cup assembly to hold it to the counter.....buster1104@gmail.com
Posted on Dec 17, 2009
  • Trent Christensen Oct 26, 2012
    I no long have this machine as it was parted out thank you.
6ya staff
SOURCE:
Bolt and washer for rival meat slicer mod 1101e/3
Meat Slicer Parts ' eBay
www.ebay.com/bhp/meat-slicer-parts
  1. Cached
  2. Similar
Meat Slicer RIVAL 1101E/4 Motor Plastic Washer Replacement Part Vintage ... Rival Food Slicer Meat Motor Holder SCREW 1101E-5 Accessory Spare Part.
Rival Meat Slicer ' eBay
www.ebay.com/bhp/rival-meat-slicer
  1. Cached
  2. Similar
Vintage Rival Electr-O-Matic Deli Meat Food Slicer 1101E-2. $45.00; Buy .... Meat Slicer RIVAL 1101E/4 Motor Plastic Washer Replacement Part Vintage. $7.99.
Food Prep & Choppers - Rival Products
www.rivalproducts.com/...manuals/food.../food-prep-and-choppers-manual.html
  1. Cached
  2. Similar
HM-743 - Rival® Hand Mixer Instruction Manual · 1042-WN - Rival® Folding Food Slicer Manual · CN-742 - Rival® Electric Can Opener Instruction Manual ... rival meat slicer mod 1101e 3 Google Search
Dec 23, 2016 | Rival Food Processors
How do I put my rival electric food slicer back together after cleaning it?
final of Rival slicer.wmv - YouTube
? 5:12
https://www.youtube.com/watch?v=miwRiW9R_Hs
Oct 22, 2011 - Uploaded by larry kuberski
This video is a demonstration of the use and safety of a Rivalmodel 1030V food slicer. ... Thank you sir for you your workputting up this video. ... Can anyone tell me how to assembly itback. .... How To Use A Vintage Rival Plastic Fold-Away ElectricMeat/Cheese Food Slicer Model #1044 - Duration: 1:30.
Instruction Manuals - Rival Products
www.rivalproducts.com/.../instruction-manuals.html
The Rival CompanyBeverage · Cooking · Desserts · Food Prep & Choppers · Garment Care ... Shop Rival®Products. Beverage · Cooking · Food Prep & Choppers · Desserts ..
Nov 13, 2015 | Rival Food Processors
How do I find a blade retainer for a rival food slicer Model 1101E/7 part 636-100. Rival no longer makes this Part #
sadly if Rival does not make it anymore then you are not going to find one . some things we just have to scrap out .
Oct 13, 2015 | Rival Food Processors
I need a Rival Mfg. Co. Electric Food Slicer model 1101E-4 blade with gear can't find one
i have a rival 1030v electric food slicer in mint its nice ive never used it its just sitting around now.
Jun 03, 2012 | Food Processors
Where can I find an instruction manual for Rival Food Slicer model #1101?
here is the full list of manuals available for rival products
Please let me know if this has the right manual?
Dec 18, 2010 | Rival Food Processors
I need a replacement blade for a rival food slicer model#1101
I own a Rival Food Slicer, Model #1101/8. I need a new blade which is 6-1/2" diameter with nylon bracket plastic gear riveted to inner side of blade and the screw which holds the blade in place. Please tell me how to go about getting one and how much it will cost. Thank you.
Sep 18, 2010 | Food Processors
Rival food slicer
www.ckitchen.com/Lincoln_Slicers.asp
They have many food slicers. You can buy or rent.
Artgirl
Jul 17, 2008 | Food Processors
Food Processors Logo
29,650 people viewed this question
Top Food Processors Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Food Processor Expert? Answer questions, earn points and help others
