These Nesco dehydrators have a bi-metal thermostat. The surface of the contacts will sometimes corrode and stick together or short with the corrosion. It can be intermittent. This causes the unit to heat to a high temperature. This causes solder to melt or the thermal fuse to blow. Take it apart and clean the contacts of the thermostat with fine sandpaper or thin file. If needed the replacement fuse is a 5x12mm, 235 degree 2.5 amp 250 volt thermal fuse available from Radio Shack online or at store. An ohm meter will tell you if the fuse is bad.
NESCO® Roaster. We offer the widest selection of quality portable roasters. Our various sizes will cook anything from a pot of chili to a 22 pound turkey! NESCO® ...
Missing: mdl ‎8900
Amazon.com: Replacement Power Cord for Vintage Nesco Electric Roaster Oven Cooker Model Cat No 126 129-2: Home ... Replacement 2pin Power Cord for Nesco 6Qt Roaster Oven Model 4116-14 (2pin 6ft) 4116... ... 4.5 out of 5 stars.
Missing: mdl ‎8900
I have had no luck in finding a manual online for your Nesco Pot Luck Cooker, model hb001.
I did find this information on the Nesco Owner's Manual Download page: http://www.nesco.com/customer_support/owners_manual_download/
(Quote)
Original copies of owners manuals are available upon request at a small fee. Please call 1-800-288-4545 for more information.
(End quote)
Take apart the bottom unit that contains the heating element. Hopefully it's put together with phillips screws. Mine are not. I'd have to drill out the brads that are holding it together. Once it's apart, use an Ohmmeter to check the heating element. Be sure to disconnect the fan from the heating element when ohmming out the element. If the element is open electrically, replace it. Good luck in finding a place to purchase a new element.
