Question about Sharp Refrigerators
How to adjust left french door to correct clouser problem. It is making a sharp noise
    Passionate:
    Visited the website for 10 consecutive days.
  • 128 Answers
Each model is different and giving us a model# greatly improves the advice we give you!
There are two ways to typically adjust the doors..
-Firstly is there is sometimes an adjustment nut at the bottom of the door that will raise and lower the height.
-Second is to adjust the feet in the front of the cabinet to shift from one side ( This raises or lowers adjacent side)
-Sharp noises are typical of LG's on the left door (models with ice and water in the door) and that noise comes from a spring loaded closer going bad.. Soon it will not close correctly and you will find it open often.
Please give us more information if further assistance is needed.
How to adjust left french door to correct clouser  - untitled2-n1dvgax2is1j2ueeyj0buc1k-1-0.png
Posted on Feb 10, 2018
6ya staff
SOURCE:
22yooper
James Helmer
  • 828 Answers
SOURCE: LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Posted on Jul 31, 2008
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: Door adjustment
Start by raising the front legs slightly to shift the directional pull of the door rearwards.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 05, 2010
Anonymous
  • 337 Answers
SOURCE: Our french doors will not lock and can see rubbing
This is almost impossible to answer without looking at the doors. I would check the hinges first to see that they are mounted properly and that the pins are all the way in. I don't know if the doors are old or not. If they are, doors can swell due to moisture. If the doors are in good condition, you should check the opening under the doors to see that it is even all the way across. This will give you a clue as to how the door needs to be adjusted. Sometimes you can place shims under the hinges. I hope this helps. It would be much easier if I could see the doors. Good luck!
Posted on Mar 03, 2010
geoff hunter
  • 4793 Answers
SOURCE: I want to adjust the upper doors on a viking
USE A SPIRIT LEVEL ON THE OUTSIDE OF THE UNIT FIRST,IT IS POSSIBLY THE FLOOR THAT IS NOT LEVEL.........USE SPACERS UNDER THE FEET......factory build them square.....
Posted on Jun 07, 2010
dennis dodge
  • 1891 Answers
SOURCE: Left side french door seem
ck the cam ( plastic ) it lifts the door and also causes it to close tight . they ware out and the sometimes just brake and fall out . .. part # 12395501 b -- this is a blk bushing . for your model .. mm
Posted on Sep 02, 2010
French door makes high pitched squeal when I open it
Lube will not help. The door needs adjustment. Look on top of the door where hinges are and try minor adjustment. You will need help to guide you.
Dec 04, 2013 | LG Refrigerators
The microwave will not come on ,however the timer starts running . If you hold the latch in slightly it will run correctly but you have to keep it pressed in. I have the sharp carousel model 1200watt
Your door is misaligned dont use it by holding it Ionce you tighten the door correctly then adjust the door switch where the door latches and make click sound Thanks Please rate me
Aug 27, 2011 | Sharp R-510HW Microwave Oven
My 3 year old Maytag with double doors and freezer on the bottom is making a humming noise. What is it and can it be fixed? Would the warranty cover it?
may be the comp lines and they need to be adjusted . other causes may be fan's / and some time the cold dampner can cause this . best to follow the noise till source is found then is't eas to correct .. mm
Aug 17, 2010 | Maytag MFD2560HES Bottom Freezer French...
I want to adjust the upper doors on a viking french door model vcff036ff. The left door is higher than the right door. It appears that I have to remove the door to adjust it. Dan
Jun 07, 2010 | Viking VCFF036 Bottom Freezer French Door...
Door adjustment
Feb 05, 2010 | KitchenAid KBFA25ER Bottom Freezer French...
Refrigerator Door not staying closed
Try to raise by adjust the 2 front footing slightly higher than the back, this will tilt the unit slightly backwards. That will help the door to close back by itself.
Feb 24, 2009 | LG LRFC25750 Refrigerator French Door
Door Pops Open
check the alignment of the doors. their is an adjustment on the top hinge. also the hinges have washers on them that you can adjust the door up and down by moving washers to the hinge under or over the door.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 12, 2008 | Amana AFD2535DES French Door Refrigerator
Door adjustment
Move the left side leveling leg down (counter clockwise) and this will raise up the left side of the fridge also raising the door.  Let me know if this helps.
Oct 13, 2007 | Maytag MFD2561HEQ 24.8 cu. ft. French Door...
Refrigerators Logo
62 people viewed this question
Top Sharp Refrigerators Experts
geob91
Elie Balas
Vernon Taylor
Are you a Sharp Refrigerator Expert? Answer questions, earn points and help others
