You just go to the link I attached I'm sure you will get the solution of your problem -
Best Manuals
SOURCE: 1981 John Deere 317 carburetor screws for the
When it comes to carb adjustmant,my recomandation is for you to seek a professional to do it for you. You can fight with it for a while and not get it,small engine mechanics that do it all the time could have your problem fixed rather quickly and wouldnt charge you much,but thats up to you.
SOURCE: John Deere Mower Engine Issue
HAVE YOU CHECKED THE CARB AT ALL? LOOK AT THE LINKAGE & MAKE SURE IT MOVES FREELY! IF CARB CHECKS OUT MAKE SURE GOVENER IS ADJUSTED RIGHT!!
SOURCE: john deer bh25 leaf blower won,t stay operational
Its probably a clogged spark arrestor on the muffler. John Deere reccomends cleaning or replacing after 25 to 50 hours.
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
SOURCE: My john deer won't go in to gear. It starts and
the drive and the mower deck use different belts
