SOURCE: kenmore front load washer Model 970-C40042-00
Click this link.
They will have a manual for you.
SOURCE: kenmore Front load washer model
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
SOURCE: Dryer won't spin on my kenmore stacked model 417.90812991
This is the 2nd time I have this problem.
IF you look thry the drum to the back you should see 3 screw heads. Mine has one screw still in the hole and 2 empty holes.
This requires the drum to be removed (like take the drier apart). Behind the drum is Asmbly-shaft (ball hitch) (item 32 in the parts list). This what the 3 screws screw into.
I spent 2 days trying to put the screws in without removing the drum not possible (no way to hold the drum in place)
The first time I had to replace the drum because it wore the rim through.
I have to get 3 new screws and some thread locker.
I recommend that you check the screws every month, Use a long phillips screw drive
SOURCE: Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
SOURCE: How do I get a repair manual for my Kenmore front loader
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
