It may depend on your particular model, but the Elna SP manual indicates there is a darning and button plate which means the feed dogs do not raise or lower.
Page 36:
ELNA SP Manual Page 23
Here are some tutorial videos that may be helpful:
Elna SU 62C Basics
At about minute 34 of the video, he puts the plate cover over the feed dogs so it is doubtful that your machine is any different.
SOURCE: feed dogs
If the machine has a 'darn' facility and this is selected the feed dogs 'will' stay down.
Other than that(without looking) i would guess a good clean and a dose of lubrication would not go amiss.
Try removing the needle plate to see of there is any compacted "fluff/lint" or indeed anything else stopping the dogs rising. Take off the bottom access cover have a good clean out and oil.
Best of luck
Rob
SOURCE: Raising and Lowering the feed dog on Janome 4900 MC
These machines are known to have this problem. The feed lift cam has a groove worn in it that won't allow the feed dogs to come back up. It is on the lower shaft and needs to be replaced. You can get the feed dogs back up by taking off the needle plate and lifting them up manually while turning the hand wheel. They should stay up until you drop them again.
Some people will not replace the cam and live with it.
good luck!
SOURCE: have a 1970's elna su supermatic but cams don't work
There are two types of discs - single and double.
For the thinner single discs do as follows:
1.Turn stitch width knob to "0"
2. Turn stitch length knob to "0"
3. Insert the single disc
4. Turn the top selector to "A"
5. Make sure the needle selector is in the centered position.
6. You may now choose any stitch length or width you wish. I usually try "3" for the width and 1/2 for the length to start.
For the thicker double discs do as follows:
3. Insert the double disc
6. You may now choose any stitch width.
7. The stitch length must be put on "A" - this is the difference between the single and double discs!
I hope this helps!
SOURCE: feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
SOURCE: the feed dogs on my elna are not moving the fabric
it could just be knocked out of gear,,, or the drive to the drive dogs has sheared off??? if thats the case its for a repair man to fix it
the drive gears are inside the machine!
