SOURCE: cant download your softwear for
ya u need 2.0 prts ok buy pci usb 2.0 then gives u 4 out back if u have open pci slot faster ports
SOURCE: Need Windows ME Driver for PNY USB 2.0 Flash Drive Attache
Here's what you can do,
Download the files using the these links,
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbauth.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbhub.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbmphlp.pdr
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbntmap.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbstor.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbui.dll
Put all these files in one folder and when windows ask for the drivers, select the option to manually serach for the drivers. And point the search to the folder where you saved these files and it should fix the problem.
If this does'nt work, please let me know.
SOURCE: 16GB Flash Drive NTFS Formatting
Assuming Windows XP, try the following:
START / RUN... / <type> devmgmt.msc <enter>
Find your USB flash drive listed under "Disk Drives"
Right-click and select PROPERTIES...
Select POLICIES tab
Select "Optimize Performance" & OK
Now select your flash drive from MY COMPUTER
Right-click & select FORMAT...
Select NTFS and format.
This should take care of your NTFS problem but note the warning about safely removing flash drive.
If it doesn't work, run "compmgmt.msc" / disk manager and check for partition issues.
Hope this helps.
SOURCE: i just bought a pny 16gb usb 2.o drive to download
Is your memory card is recognize by windows or you didn't see it on windows explorer!
if you dont see it on explorer it could be solve by a service pack!
and if you see it on windows explorer but can't copy anything the card may be locked with the little tab on the side of the card!!
SOURCE: I do not now how
Hi.
Could you please let me know the Operating System installed in the Computer?
Once you let me know the Operating System installed in the Computer, I can provide you the detailed steps to perform the Backup on the USB Flash Drive.
Please feel free to contact for further assistance.
Thank you,
Suresh
