Freezers Logo
Sam Saitowitz Posted on Feb 05, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My chest freezer runs 24/7 I have replaced the seal and have check that the thermostat switch off. Should I have the gas checked?
Bruce Mommaerts
Level 2:
Scholar:
New Friend:
  • Expert 119 Answers
  • Posted on Feb 05, 2018
Bruce Mommaerts
Expert
Level 2:
Scholar:
New Friend:
Answers
119
Questions
Helped
37918
Points
284
If you want to turn the freezer off just unplug it. If you want it to keep cold but not run continuously turn the thermostat back on and set to lowest setting
5 Related Answers
Anonymous
  • 625 Answers
  • Posted on Sep 11, 2007
SOURCE: Replacement thermostat in chest freezer
in order for the "stat" to sense the coldness of the freezer box it needs to be within the chilled space. it is probably held on by a couple of clips on the underside of the freezer compartment on the evaporator plate.
Anonymous
  • 290 Answers
  • Posted on Sep 25, 2007
SOURCE: kenmore chest freezer not working
Remove the panel covering the compressor. Remove the relay plugged on the side of the compressor and shake it. If it rattles or has any burned spots it is shorted out. Try replacing it first. Make sure you replace it with the correct replacement, not a fit-all. If this is not the problem you will need to replace the compressor. If it is less than 5 yrs old the compressor should still be in warranty. If so call Sears, it will be repaired free of charge. If it is out of warranty buy a new freezer.
Anonymous
  • 124 Answers
  • Posted on Nov 02, 2008
SOURCE: freezer stops and start
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Anonymous
  • 291 Answers
  • Posted on Nov 25, 2008
SOURCE: chest freezer ices up quicker than it should
if the box has mold between the seal and liner the the seal isn't the main problem, the main problem is the liner is bad and by time you got both parts if you can it would cost more than to replace the freezer.
Larry
Anonymous
  • 410 Answers
  • Posted on Jan 30, 2009
SOURCE: chest freezer not freezing
home refrigeration units are not designed to work in low temperature areas. where temps will drop below 45f so that is your problem. this is listed in your owners manual if you want to verify. thx peyton
Why My haier model hcm070la Chest freezer the compressor is not kick on
check thermostat, or relay on one side or back cclose to the compressor area there is a removable lid. removed and look for a thermostat disconect the 2 wires and bridge them then plug the the freezer on if runs replace the temp thermostat for a new one should be freezer thermostat
Hi we have a norfrost chest freezer it is freezing everything but bread on superfreeze when we take it off of superfreeze it defrosted the bread
sounds like the thermostat is at fault or more than likely the refridgerant gas has partially escaped due to a leak, check te seals on the doors first. hope this helps.
Oct 09, 2016 • Freezers
Freezer runs continuously even on low setting.
Check you tube just go to you tube and type in what the freezer is doing .I've found a lot of things on there .
1helpful
Igloo chest freezer 7.2 cubic ft seems running all the time?
It may be on "superfreeze", if there is a yellow light, or it may be set for too low a temperature (try setting the thermostat down to 1 or 2). Check the condenser is clean, and fan working if it has a fan, Check lid is closing properly and the ambient temperature isn't too high.. Lastly, if all else working correctly, suspect short of refrigerant.
Compressor runs but freezer not getting cold
Have the gas checked. If the thermostat pick-up is frozen over that could result in the contents of the freezer not getting cold, but for that there would have to be a build up of ice on the sides of the freezer.
Would a bad thermostat cause my danby to not completely freeze?
Should operate 24 hours before putting anything in that is not already frozen. Check it again after it has run for 24 hours. Anytime you adjust the thermostat go one click at a time and wait 24 hours for it to stabilize.
eric
Small Kalvinator chest freezer quit working,
If not running then jump out thermostat. If running then throw it out as it has a sealed system issue not worth repairing unless it is under wty. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Chest freezer runs almost non-stop.
hi. thanks for the question.you said you could not set the thermostat any warmer. so no matter what you do. it is not changing a thing. -5 the block of ice on the back, is a sign of too cold & running to long. was it frosted up inside the freezer i would replace the cold control thanks the appliance doc
Sep 28, 2008 • Freezers
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
