You could have a bad timer or cold control and the light could have failed from the heat but try banging on the control,not to hard,it can stick when it fails and sometimes a good wack will get it going the timer is also there where the cold control is,there's a hole below the timer,if you stick a flat head regular screw driver up in there you can turn the timer out of defrost, just one or two clicks,if everything starts to run the timer is bad but i would check them if you unplugged the fridge and plugged something else in the plug to make sure you have power there
