Question about Irons
How do you clean brown stains off The sole plate
  • 2,896 Answers
Hello, John -
See this web page which provides several iron soleplate cleaning methods:
https://www.wikihow.com/Clean-the-Bottom-of-an-Iron
I have used the first method listed, with great success.
Best wishes.
Posted on Jan 30, 2018
6ya staff
SOURCE:
Anonymous
  • 1605 Answers
SOURCE: goo on iron sole plate of new iron
let the iron cool completely, use #00 steel wood with dish washer detergent. rise it off with clean water.
Posted on May 13, 2009
Anonymous
  • 67 Answers
SOURCE: trouble cleaning Sunbeam iron 3983
you can buy an iron cleaner from your hardware store, wallmart sell it.
Posted on Jun 11, 2009
Frank Meola
  • 512 Answers
SOURCE: leaky water from sole plate
Open up iron, see if hose connected to tank came off. If you dropped iron a few to many times you could have cracked tank. Open up and you will see problem.
Posted on Jul 17, 2009
kirtec auto
  • 1348 Answers
SOURCE: is posible to clean iron sole plate by steel
use the green no scratch pads,they are not so abrasive.
Posted on Sep 09, 2009
FinIlkka
  • 571 Answers
SOURCE: sole plate leaking
This IS a steam iron? The iron must be hot for the steam to form. If it's not hot enough, the water is leaking thru the steam holes. Also if the channels are calsified (boiler stone has formed into the steam channels) this may happen.
Posted on Nov 04, 2009
Cannot get black stains off with the cleaner kit from Rowenta that I bough at Bed Bath and Beyond. Used almost all of the cream and still not clean. adjina39@aol.com
Are you heating up the soleplate first to get it really hot, then put on an oven mitt to protect your hand, squirt cream onto a folded pad of clean cotton fabric, then apply to iron sole plate, rub over stained area gently, wait, then rub off. you may want to rub the whole iron sole onto a piece of waste fabric to remove the burnt bits. Itcan take a couple of goes to clean. The ironing press cleaning sticks work well too.
Nov 03, 2013 | Rowenta Irons
Staining comes out with steam **** deposit on sole plate
If you manage to clean it, use only distilled water in the future.
Tap water is only fit for human consumption.
Jun 29, 2011 | Bosch Irons
I have brown marks on the soleplate of my electric iron can i get them off
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaning a Steam Iron Soleplate
heatman101
Jul 02, 2010 | Kenmore Professional SR365S Iron with Auto...
How to repair aan electrical iron
If the iron doesn't heat, make sure power is on to the outlet, check the electrical chord, and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical chord . Also test and, if needed, adjust calibration of the thermostat.
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the sole plate. If the iron stains fabric, clean the sole plate, clean the tank with a commercial cleaner, and use distilled or filtered water.
The tools you will need are
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial sole plate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
Please rate my solution.
Jun 25, 2010 | Rowenta Professional Luxe DM880 Iron
It is dirty - how do you clean it. I think
RUB ON A BROWN PAPER BAG ON TOP OF A TOWEL ON MEDIUM TO HIGH HEAT.
Mar 17, 2010 | Sunbeam 4214 Iron
Remove build up from bottom of the iron there are brown stains from fabrics on the iron - want to know how to remove them
Turn the iron on hot. When the stuff feels like it's loosened, take a newspaper and 'iron' it. If you still want to get off more, take a razorblade and shave off as much as you can. If you keep the blade nicely parallel to the iron sole you cannot damage the sole.
Don't use the blade on teflon-coated iron!
Nov 04, 2009 | Rowenta Irons
Trouble cleaning Sunbeam iron 3983
Jun 09, 2009 | Sunbeam Best Value 3983 Iron
Goo on iron sole plate of new iron
May 13, 2009 | Euro-Pro Shark GI490 Iron
BRown water and stuff coming out of iron
Hi, two problems:
DIA' s problem - the brown water is due to poor water quality and debris in the boiler and iron sytem. Rowenta is clear that they do not want anyone to cleaning solutions - only clear filtered drinking water to rinse out the boiler (via the water inlet screw hole) and I have found running the system dry, letting it cool, rinsing and draining the boiler several times before putting unit away works fine.
Guest' problem with brown/black tar substance is likely caused by too hot and iron setting (steam setting may also be too high) for ironing man-made synthetics (like Nylon, Rayon, Polyester or blends are basically petroleum based fabrics) that breakdown or melt, leaving deposits on the iron's stainless steel soleplate. A secondary cause could be bad water or debris in the boiler/iron in which the solution for DIA's problem might provide relief. Cleaning the soleplate is tricky, I use nothing stronger than an old fashioned wooden orange stick to gently scrap of all traces of the "stuff" and dry "Dutch" cleanser w/ a terry cloth or old cotton sock to polish without scratching the soft stainless soleplate...
Apr 01, 2008 | Rowenta DG-980 Iron
Irons Logo
121 people viewed this question
Top Irons Experts
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you an Iron Expert? Answer questions, earn points and help others
