Has part in light circuit with #36445. Is that a watt regulator?
Is the fan and light kit equipped with a wireless remote control? If so a short in the light fixture sockets will cause a backfeed into the electronic circuit boards of the remote controls receiver and burn it out. If you have a voltage tester or pigtail with a light bulb remove the screws for the light kit and disconnect the two wires from it. Connect your voltmeter or pigtail to the two wires that were connected to the light kit. Have someone turn on switch for light or push light button on remote and see if you are getting power, If you are then problem is in light kit. If no power is present then receiver for remote is burnt out. Depending on the fan receiver can be built into the fan or located inside the top canopy and can be easily replaced. As per the light kit having a watt regulator it is possible that was installed to prevent overheating of the sockets by the manufacturer. That can also have blown out causing no power to get to the bulbs. If you have power at the wires that connect to the light kit then the watt regulator is defective. You can bypass the part but you must insure that you do not install bulbs that are of a higher wattage then what the fixture is rated for. Or you can order a replacement from Hunter. Good luck.
SOURCE: Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
SOURCE: Ceiling fan lights do not work
You may have shorted out the light kit. Did you remove the other bulbs and put in new ones? They may have all blown when you heard the noise. Try that first, and if it still doesn't work, you may have to buy a new light kit. They are not expensive, and you can buy one without the glass bulb holders or cans, whatever you have. Then you can still use yours after you install the new light kit. Good luck!
SOURCE: Minka aire ceiling fan
This may not apply. There could be an electrical problem. But if you installed the bulb with your hand, the oil on your skin can cause the buld to heat excessively and fail. I suggest you use the packaging or part of it when installing it, taking great care not to touch it.
SOURCE: broken globe on Hampton Bay Ceiling Fan (Vercelli model HD278017)
My fan just stopped working - no lights no fan :( and I just can't seem to find any type of switch - only the remote, which lights up just fine. Can anyone help???
SOURCE: Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
